That controller should work OK. Get the 500w one because they don't specify the current, and 500w controllers are normally around 20 amps, which is what you need. If you like the bike, it's pretty easy to upgrade to a lithium battery, but you need one that can continuously give what the controller allows, so about 25 amps, which excludes most of the cheaper ones. In other words, you can't just buy any 36v lithium batteryThanks I'll check that.
I agree it's not worth investing much but ii this the sort of thing?
24V 36V 48V 350W 500W e-Bike Motor Brushed Controller For Electric Bike Scooter | eBay
Find many great new & used options and get the best deals for 24V 36V 48V 350W 500W e-Bike Motor Brushed Controller For Electric Bike Scooter at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
and a thumb throttle about another 12 quid brings total spend to around £85, may be worth it, not sure. I don't like the idea of throwing it away.
Is the battery monitor likely to work with another controller, else can it be reused in any way?
Where can you "a set of cheap mobility gel battery for 3 x £15"!!! I've not seen a set under about £90.
In principle what are the differences between lead acid and lithium performance?In other words, you can't just buy any 36v lithium battery
If you order three the checkout price including VAT and delivery is £55.92 as they only charge for one delivery, so £6 more than my rough figure.@Openspaceman So far as the batteries in your link are concerned, they are perhaps a little cheaper than I have seen, but not much - they are £16 not £15, plus £8 delivery for one battery - there doesn't seem to be any way to find out how much it would be for three until you pay.
That's a good price, however the originals were 12V 14Ah and the nearest equivalent is their 15Ah battery, the price of that even allowing for the extra capacity, isn't anything special. Perhaps higher capacity in the same physical size is bound to be more expensive.£55.92 as they only charge for one delivery
Energy Density by Weight (Wh/Kg) | Energy Density by Volume (Wh/L) | Cycles (*) | Self Discharge Rate (%/month *) | |
Lead-Acid | 40 | 75 | 71 | 11.5 |
Lithium | 150 | 420 | 500 | 4.5 |
Ratio | 3.75 | 5.5 | 7 | 0.4 |
# The notes appear to suggest that this is for 100% discharge.
Your "common sense" figures are way off and you're missing some vital knowledge. How much "experience" do you have - not much, it seems. Firstly, you can't empty an SLA battery. You only get about 6Ah out or a 12Ah one. Where can you find a 7.8kg 24v 8Ah lithium battery and why are you using that instead of a 36v 14Ah one? The average 500wh lithium battery weighs about 3.5 kg with the case. The cells weigh about 49g each, and there would be 40 or 50 in a typical ebike battery, so the actual cell-pack would be 2kg to 2.5kg. I think you need to do a bit more research about ebike batteries before you publish figures that are so misleading.@Openspaceman Here is the (rough) calcuation (rounded to one decimal place)
Capacity
Pb 36V x 14Ah = 504Wh
L 24V x 8Ah = 192Wh
So size and weight of L need multiplying by 504÷192 = 2.6
(Any error in estimating its size or weight will also be multiplied by 2.6)
Size
Pb 3 off 15.1 × 9.8 × 9.8 = 4351cc
L 2.6 times 7 x 7 x 24 = 3057cc
So size of Pb is 4351 / 3058 = 1.4 times as much as L
Weight
Pb 3 off 4.7 = 14.1Kg
L 2.6 times 3 = 7.8Kg (3Kg including case plug etc, at a guess 2.5 without)
So weight of Pb is 14.1 / 7.8 = 1.8 times as much as L
These figures pass the common-sense check and reflect my experience with the bicycles concerned in practice.
