I did a tubeless conversion on my rear wheel, as it's the one that would cause most pain in the bum to repair a puncture on. It's worked fine so far, and cost next to nothing. I can't say how many punctures I've not had with it - I haven't fished anything out of the tyre carcass, yet this area is strewn with thorns at the end of summer and they lie in the ruts all year long, previously causing me some grief. I've had no thorn grief at all, since going tubeless.When I do get my bike, which is very soon I hope, I would like to make it a puncture free life. Being clumsy it takes me ages and ages to change inner tubes.
Can anyone recommend tyres that offer high puncture resistance?
Taff
My xtrme has these inside a set of Marathon Plus MTB tyres. I reckon at this means at thickest needs a 8 mm plus object to pierceI'm a big fan of the Giant Thorn proof tubes, tyres stay up for ever and no punctures since I started using them. Basically a much thicker tube - I couldn't believe how big the boxes were when they arrived. and just £1.75
link
Appropos of nuffin....My xtrme has these inside a set of Marathon Plus MTB tyres. I reckon at this means at thickest needs a 8 mm plus object to pierce.
Has added a bit of weight but handles fine and as its a ebike cant really tell the difference.
I bought something similar from Buyology, for a quid a can:Maybe someone else who has used it can confirm if its any good.
Ive done same with mine, but just fitted a Kanda heavy duty tube to wifes 24inch road tyre and it was like stuffing a pair of jack boots inside. Dont want to do that again.My xtrme has these inside a set of Marathon Plus MTB tyres. I reckon at this means at thickest needs a 8 mm plus object to pierce.
Good that it works then. My nephew has a puncture in a bog standard mountain bike so might test it on that.F
Haven't used it yet, mainly because I can never find the thorn in a fairly knobbly tyre, so can't extract it without taking the tyre off & running my fingers round the inside:
The utterance of a coarse expression then indicates the sharp objects location
I think it was d8veh who warned that you still need your pump with you.
+1 on the tyres - fitted a pair of those in 2.1 size to the Trek. With these inner tubes which don't "balloon" if punctured - they compress to self-heal hopefully enough to get you home on the puncture :My xtrme has these inside a set of Marathon Plus MTB tyres. I reckon at this means at thickest needs a 8 mm plus object to pierce.
This is exactly how I made mine. I didn't use Stan's, as I regarded it as a rip-off for what is more or less latex, but made my own latex mix.Good that it works then. My nephew has a puncture in a bog standard mountain bike so might test it on that.
Noticed this as well
No flats tubeless tire system - YouTube
As I said its fine. I reckon it would have to be going stupidly fast for it to have any affect like that after all a motorcycle wheel weighs far more and you can steer one of those fine.Appropos of nuffin....
It occurs to me that there must be a quite significant gyro effect caused by that much mass at the rim.
I wonder if the centrifugal force generated on a decent descent would be enough to affect turnability?
