I guess if the cover is really tight then the leverage is not enough because the screw is so close to the centre pivot.
I'm thinking ahead to when I might need to remove the cover from one of my Q100 motors.
Looking at CWAH's difficulties I think I'd be tempted to make a simple spanner.
A steel bar about 5mm thick with a hemisphere cut out to fit round the hub centre, and two holes to fix it to the plate with two of the existing motor screws (5mm longer).
I think a sharp tap with the club hammer would then do the trick with even a very stubborn thread.
