Sale At Evans
jerrysimon
3,292
112
Cambridge, UK
indalo
Banned
Sep 13, 2009
1,380
Herts & Spain
Nice find Jerry!
I rather like that and I'd have to shortlist that with the Brompton amongst a few others, were I to consider a folder. The sale price seems not unreasonable if it has decent build quality and other Dahons I've looked at seemed pretty fair to me.
Indalo
jerrysimon
3,292
112
Cambridge, UK
Yes Indalo,
I notice the new Brompton H model (handle bars 60mm higher and 13mm further reach) is available now too.
Brompton H3L 2012 Folding Bike | Evans Cycles
Mind you they have gone up in price a lot £845!
Mine cost £600 in 2009. Also I can't wait to see the Brompton E offering this year.
Regards
Jerry
30,812
Shop around to check though. The rift in the Dahon firm splitting it into Dahon and Tern brands has resulted in many Dahon models at big discounts from various sources.
Evans say they have price match, but I don't know if that applies to online sources as well.
eddieo
Banned
Jul 7, 2008
5,070
I had the original twin suspension Jetstream and it was a lovely bike. BUT if you want to use bike on trains/cars etc.... Still think Brompton the best bet. Can buy used for approx £500'ish
Scottyf
1,403
-1
Nice bike and I would imagine quite a nice ride too.
Least its got the v brakes in the correct place ;-)
cwah
3,048
179
www.whatonlondon.co.uk
I tested the Jetstream, but I didn't like it:
I had the impression that the suspension were too strong, it was like it didn't work. And I love so much the "pschhhh" sound of the real air suspension when you bounce that I want something like this now :cool:
The Downtube FS seems cool too:
Thanks Jerry, just ordered one for my next project. I just hope that the drop-outs are wide enough for a motor. I had a good look round but couldn't find it cheaper. There's an extra 3% off (£18) if you order through Quidco.
jerrysimon
3,292
112
Cambridge, UK
Damn I should be on commission :p
Dave make sure you update us all when it comes, together with lots of pics of your build.
I suspect the dropouts, on the front anyway, will be the usual Dahon 74mm ?
Regards
Jerry
jerrysimon
3,292
112
Cambridge, UK
Yes cwah the Downtube does look nice I agree.
And its 16" wheels isn't it ?
If it is, then it must be one of the only modern foldable fully suspened 16" wheeled bikes available ?
The Jetstream has 20" wheels.
Regards
Jerry
cwah
3,048
179
I think it's a 20" wheel for the downtube FS. So it's not the smallest fully suspended available.
D3v8h, the rear dropout of the jetstream seems to be 130mm:
I have confirmation to day that the rear dropout on a Dahon Jetstream is 130.5 mm, but I think Andy's measurement of 130 mm is likely to be correct. Either way, 0.5 mm isn't going to make difference and I now know that an eZee rear wheel motor will fit for sure.
Reference: http://www.pedelecs.co.uk/forum/electric-bicycles/8319-dahon-20-rear-drop-out-width.html
shemozzle999
2,826
686
jerrysimon
3,292
112
Cambridge, UK
Nice video. No way is that a 250w motor. That thing is a jet :eek:
I think I would put the motor in the front and a 2, 3 speed (or Nexus if I had lots of hills) contained hub on the back.
PS just checked its a 500 watt motor with a ecrazyman 72v 45amp controller!
Highly illegal in this country (wink wink)
No wonder the young man is smiling at the end lol
Regards
Jerry
shemozzle999
2,826
686
I think the opening shot shows a 250w with a bottle battery setup..
Please don't watch the rest of it. ;):eek:
It was only info for d8evh, honest, couldn't find a front motor setup, it says in the spec that the front forks are a special narrow setup and they barely look wider than the tyre which is only 1.5".
Think they also do a contained hub version Jerry.
regards, Colin.
C
Cyclezee
I got a Dahon Jetstream last year for customer in Greece who wanted an eZee conversion kit fitted. The bike came from Folding Bikes, Dahon, Brompton. Fudges CycleStore for £560 including delivery, but they are currently out of stock. It really is a lovely bike, personally, I prefer it to a Brompton.
I had one my self a couple of years ago and was going to convert it for my own use, but I have no real need for a folder.
Can you remember where you fitted the battery? Ant photos?
cwah
3,048
179
Why fitting the motor on the front fork? Wouldn't that be stealthier on the rear?
My new Jetsream arived today. It took all of about 5 minutes to take it out from the box and assemble it ready for riding. I just had to insert the seat-pin and screw on the pedals.
I checked it over to see if there were any faults and it looked pretty good apart from a scuff on the frame that had removed paint in an area of about 6mm dia, the pedal bearings were very notchy and while I was doing up one pedal, the end was going backwards and forwards so the spindle must have been bent.The pedals are definitely the weak point. They're very heavy as well because of the folding mechanism, so with the other problems too, I might change them. Can't fault the rest of the bike though.
I tried it down to the supermarket and everything worked. I didn't need much pedal effort because the gearing goes very low, but of course the speed was also correspondingly low. Everything had been nicely adjusted by Evans - gears, brakes, etc.
The suspension seems not bad considering I haven't adjusted anything. The front suspension seemed better than that fitted to most electric bikes, but obviously not like the air forks fitted to my other bikes. the back seemed a little more harsh, but, again, I'm used to air suspension.
I looked it over when I got home and spotted a little spring-loaded plunger attached to the front linkage, but I can't find any purpose for it. Unfortunately, although I got three different manuals with the bike, there's virtually nothing specific to this model that explains the front suspension (or anything else useful for that matter). I think that's poor on the part of Dahon.
The drop-outs are 70mm front and 130mm rear. I know you can fit a large motor in the rear because people have already done it, but I don't want to do that as I already have powerful ebikes. I want something quick and convenient to get out of the house and down to the shops with good climbing power to get me back up the steep hill with my shopping. I keep my much faster and more powerful Giant BPM in the porch and it's a bit wide to get through the door. the Dahon goes through easily.
I'll probably use a Q100 cute motor that I have lying around.
I'll put some pictures and explain the electrical choices in a new thread tomorrow,a fter I've had a good look at the bike.
Thanks again jerry for pointing this one out. I'm pretty sure that this is exactl what I was looking for.
jerrysimon
3,292
112
Cambridge, UK
Thanks for the write up Dave.
I guess you could fit the Q100 but the Q85 is narrower which means you won't have to spread the forks.
Ps you mean this bit
No idea but someone may know.
Regards
Jerry
shemozzle999
2,826
686
QUOTE]
Might be worth asking the question on their forum d8veh.
Jetstream P8 Front Suspension - Dahon Folding Bicycle Forums
I think it is a wise move of yours to restrain the power on this bike.
