Help! What's the highest torque front motor (still UK legal)
chris667
164
108
Hello
Thinking about ebike MK2.
I'm looking for a high torque, low RPM motor for a 20" wheel bike.
Any suggestions?
2,078
High torque in a front motor makes the wheel lose traction, especially on hills. It's even worse with 20" wheels because the torque is proportionally higher than with larger wheels.
You need to tell us about what speed you want, what weight you have and what sort of hills you need to go up rather than focusing on a single characteristic.
To answer your question, it's probably one of the Heinzmann motors. They run at about 28 amps. They state that their cargo motor can pull 300 kg up a 13.1% hill. That's with a 250w motor!!!!!
It takes 981w to lift 100kg at 1m/s. lets say the bike would climb at 8 mph. That's 3.6m/s, so on a hill of 13.1 %, the vertical speed would be 0.468m/s. Therefore the power needed to lift that 300kg bike up the hill would be 3 x 981 x .468 = 1377 watts of output. That's quite a powerful 250w motor then, when you consider that a Bosch CX gives around 500w when climbing. Input power would be over 2kw.
Wait, it gets even better. They make twin 125w motors that are certified to EN15194 when combined, and can pull 500kg up a 15.8% hill with their combined 250w. This seems to answer the question of whether multiple motors are allowed. You just need to find the right 125w ones.
Reactions: Oldie
30,381
Wait, it gets even better. they make twin 125w motors that are certified to EN15194 when combined, and can pull 500kg up a 15.8% hill with their combined 250w. This seems to answer the question of whether multiple motors are allowed. You just need to find the right 125w ones.
The legality is addressed it seems by having a master controller with the second as a sub system or slave. But they intend this system for multitrack use such as the rear wheels on a trike in lieu of a differential system.
As well as the twin 125 Watt motors they say they can also supply twin 250 W for where that is legal.
