Throttle use Poll
When do you use your throttle if fitted? 107 members have voted
  1. 1. When do you use your throttle if fitted?
    • I never use a throttle.
      4%
    • I only use throttle on start up to help get going.
      20%
    • I use the throttle occasionally to rest my legs/heart/lungs.
      23%
    • I always use the throttle.
      34%
    • I do not have an independent throttle on my pedelec.
      16%
Please sign in or register to vote in this poll.
Hi Pedelecers all,
I wonder of you could help me with a poll regarding the use of a throttle on your pedelec? BEBA has become involved with the question of whether they should remain legal. I am sure you know our position but we would very much appreciate finding out what the feeling is amongst the pedelec riding community.
We need to be quite general so please chose one of the following categories that is closest to your riding style, if you do not have the advantage of a throttle on your bike please choose option 5.
Of course I would also be pleased to hear your views on the need for a independent throttle on a pedelec if you have time to post.
1. I have a throttle but never use it.
2. I only use throttle on start up to help me get going.
3. I use the throttle occasionally to give my legs/heart/lungs a rest.
4. I always use throttle.
5. I have a pedelec without a throttle.
Many thanks and best regards
David
Edited by Wisper Bikes
  • Replies 115
  • Views 20.4k
I think you will find that most hub bike riders with a throttle will be very reluctant to lose them. But I think most have not tried a crank drive bike and dont appreciate how refined a non throttle bike can be, plus the lack of noise a real bonus.
I try not to use the thumb throttle on my hub bike, as main use is local transport and exercise, but probably would if under pressure, commuting etc...
Addition?
6. I only have a throttle on my bike.
I did think of adding this however the bike is then no longer a pedelec, but thanks for the suggestion Shemozzle.
Regards
David
Throttles improve safety by reducing take-off wobble. I would argue for more throttles. I myself ride a bike with several of them...
Me too...even with crank motor I do like my throttle to set off, say up a hill, or in traffic.....I find it seems safer, which is why I thought long and hard then waited for my particular bike....I think it gives me the best of both worlds.
Lynda :)
In that case may I suggest either more whisky or some cycling lessons?
I like the throttle to give instant help, as the gearing on many ebikes is quite high then it takes longer for the power to kick in when starting off. With a lower gear the pedals would turn quicker from standstill and the power would cut in faster, without that then I'll carry on using the throttle to start off.
I also use it when riding on snow or ice as pedalling can cause the back wheel to slide sideways.
Addition?
Another throttle only user here.
However as I use the lower powered/more fragile Tongxin motors I never start off on the flat or on a hill with throttle, but only use it once I get moving if needed.
Regards
Jerry
Edited by jerrysimon
Regards
David
Then my legal Brompton Sparticle does not qualify?
I sort of use the the throttle all the time:
I have a cruise control that sends an adjustable, but continuous signal to the throttle input. I pedal all the time, so I decide how fast I want to go and then adjust the cruise control to adjust how much effort I put in, so I use it as an effort control rather than speed control. When I want to slow down, I feather the brakes, which cuts it. When I want to accelerate again, I just let go of the brakes.
I have a pedal sensoe, but the power it gives is too much.
I also have a normal throttle, but never use it. For the poll, I said I used my throttle (cruise control) nearly all the time
I removed my pedelec.
A throttle is a must for narrow paths, you can drag your feet. Also starting off and crossing a main road is much safer with a throttle
I should also add I don't ever just use throttle (or very rarely) always assisting by pedaling until I reach 15mph and then I shut the throttle off as its not contributing.
"thinks" does that make sense ?
Regards
Jerry
I would be lost without my throttle as a example i was out the other day and when going up a hill there was road works on the hill. So when i got to them the lights controlling the road works had turner to red if i had not had my throttle i could not have paddle of on the green as the bike would be to heavy .
Blast!!!! I should have added that one Bob of course they make pedelecs safer!
I dont think I can though, I will however try.
All the best
David
Exactly the way I use my throttle D8veh, as well as start up and the odd rest (less frequent now!). The throttle allows a rider to set the assistance to exactly the correct level for the individual's requirements and of course can be increased or decreased without taking your eye off the road or your hand off the the handle bars.
All the best
David
Regards
Jerry
Welcome to the exclusion list Jerry :rolleyes:
I voted anyway :p
Edited by shemozzle999
Throttle for myself. Never got along with Pedelec even when using the smaller bafang.
Mainly becasue it caused a small increase in drag past the 15-17mph of when I like to cut into the free wheeling.
It maybe becasue I ride a motorbike and it feels much familier with a throttle.
I've voted that I always use a throttle since that's my current bike's method, but I also like the better pure pedelecs without throttles. Both have their advantages and I've enjoyed both to the full. If I had the space I'd still be riding both types for differing purposes.
Excluded and now not "pure" beginning to get depressed ;)
I thought I needed a throttle but when I tried out different types of bikes I realised I didn't need one when using a crank driven bike.
I voted anyway :p
Me too :p
I voted always use throttle which is interestingly most popular so far.
Jerry
Me too :p
Jerry
Seeing as hub motor/throttle bikes are cheap and plentiful thats not to surprising is it....dont make them the best mode of transport though
