December 28, 20196 yr Very new to this ebike lark, so please be gentle! I recently bought a s/hand Ancheer ebike locally [although it has the Myatu logo on it- it's the Ancheer power plus mountain bike. - 36v 8AH bottle battery pack marked 2017 The guy I bought it off had it from new and reckoned it had been used lightly, but fairly regularly. [He was thinking of upgrading and wanted rid] So I've had it for a week or so and am trying to get to grips with it's foibles. The problem is that although it's fully charged - showing 3 green, once I've ridden it for a couple of minutes- even in low PAS mode, it just dies and all the the lights on the display go out. [the 3 green still light up though]. Reset on the battery on/off and I'm good for a couple more minutes before tha same thing happens again. Given that I live in a very hilly area, this is not good. Before I start panicking and go out and spend a load more dosh on a new battery I thought I'd ask you good folk here what the possible problems might be: an intermittent connection fault? a dead/dying cell in the battery pack? an electronic glitch? something else entirely? Bear in mind that this is my first ebike so I'm still 'testing the waters' as it were and I'm not yet ready to go out and spend a grand or more on something new and shiny.
December 28, 20196 yr If it is the battery sounds like cells or some are knackered tbh, might only be a bad cell or two causing a severe voltage drop or current draw to be low. What you need to do is measure/check the voltage with a meter after it is charged to see if there is a problem, like wise when out on a run also check the voltage when it cuts out. For a couple of quid you can buy a very basic led type two wire small meter to rig up for checking, they give voltage reading, % reading and a capacity bar/indicator. If the voltage under use doesn't collapse then the controller is likely to be at fault, the only way to know is see what occurs to the voltage by monitoring it .
December 28, 20196 yr If it is the battery, do not rush out and buy another one but send your old battery to Inmarsat. They will open and check it, as said above, might be just a faulty cell. In any case it will be cheaper to get the case re-celled.
December 28, 20196 yr Author Inmarsat? the only company I know of called that deals with high end Satellite phones [with prices to match]
December 28, 20196 yr Author Thanks guys. will check out battery when I get my multimeter back off the guy I loaned it to. I'll report back and see where we go from there. If the battery is ok, then it might be the controller. I note that they are'nt that pricey.
December 28, 20196 yr I had a similar problem once and it was the key barrel. I had that replaced and it’s been good ever since.
December 28, 20196 yr Author I had a similar problem once and it was the key barrel. I had that replaced and it’s been good ever since. cannot think that it is that, since all the key does is lock/unlock the battery into the carrier.
December 28, 20196 yr cannot think that it is that, since all the key does is lock/unlock the battery into the carrier. Some battery lock keys also switch the battery on, I had one that worked like that but it was a rack battery so probably not applicable to your bottle battery. Dave.
December 29, 20196 yr Most bottle/down tube batteries only have a lock to secure it to the dock cradle, most have a separate on/off switch that switches via the BMS.
December 29, 20196 yr I had a pair of batteries that did a similar thing a few years ago, both near full charge and both only working for matter of yards before no power, after checking out the batteries the fault was found to be an issue with the main controller.
January 4, 20206 yr Author Ok. guy who has my multimeter has gone on his hols, so I bought one of those led voltmeter things off the bay, and checked the voltage- 100% ok, and this is after I'd been round the block a couple of times and had a half dozen resets. Plan now is to wire said voltmeter into the battery 'spikes' on the holder so I can monitor what happens on the move. Good idea- or not? Might experience a bit of a voltage drop if I have more than a foot or so of wire, but it should give a decent indication of what's going on. Gut feeling? it's the controller, but is it an electronics issue or a loose conection somewhere in the system?
January 4, 20206 yr Ok. guy who has my multimeter has gone on his hols, so I bought one of those led voltmeter things off the bay, and checked the voltage- 100% ok, and this is after I'd been round the block a couple of times and had a half dozen resets. Plan now is to wire said voltmeter into the battery 'spikes' on the holder so I can monitor what happens on the move. Good idea- or not? Might experience a bit of a voltage drop if I have more than a foot or so of wire, but it should give a decent indication of what's going on. Gut feeling? it's the controller, but is it an electronics issue or a loose conection somewhere in the system? There won't be any voltage drop along the wires going to your voltmeter since it will draw negligible current. Use it to monitor the signals going into your display as close to the display as you can.
January 5, 20206 yr Author so........... I hardwired the voltage indicator into the battery connections and powered up the system. The battery showed 3 green. The led indicator showed a full battery. The controller gave a full bar of lights. I selected mid-range and off I went. The controller indicator lights almost immediately dropped to 3 lights, the led showed 100%. 10 seconds later the controller dropped to 2 lights and then switched the motor off and went dark. The led voltmeter showed 100% for a couple more seconds and went dark. I reset everything and repeated the experiment with exactly the same results. So, learned gentlemen [and ladies] WTF is going on. duff Controller? iffy Battery? Both?
January 5, 20206 yr That shows that the battery is probably OK and the problem could be with the display (ie the thing you call the controller), the controller (with the power electronics which I think is the box on your down tube) or the wiring / connections.
January 6, 20206 yr Author so it looks like I'll be replacing the controller. There's a lot to choose from out there, but since this is a cheapo bike, I'm not minded to splash out for a top end bit of kit. On the other hand I don't want to replace my crapped out controller with another cheap'n nasty one. so recommendations please for something compatible that will do the job without my spending more than the bike's worth. Ancheer bike - 36v/8.6A/ battery ; 250 W motor
January 6, 20206 yr Author Show us a pic of the controller with label and the connectors. will do when I get back home later in the week.
January 10, 20206 yr Author there you go. looks like a generic cheapo controller the usual jumble of cables
January 10, 20206 yr A 15a KT controller kit will be the obvious choice but I think you still need to confirm if the battery is any good, the small battery meter that gave 100% all the time is not correct. In the settings you have to configure it for the voltage in use other wise they don't give a true pic of what is happening. Try a static test with a digtial volt meter, with the motor running apply gently the brake to apply load and see if the voltage crashes or not.
February 4, 20206 yr Author well, after a lot of too-ing and fro-ing with all manner of replies and opinions, I eventually took the plunge and invested in a new x-go bottle battery as a replacement. I duly wired it in and did a trial run. Success! Lets see how long it lasts. Now- what to do with the existing battery. Answers/ comments? welcome.
February 4, 20206 yr The old battery has likely had it but as an exercise you could open it and carry out some testing to see what has occurred, you need a proper multi meter though. It might be some knackered cells or an unbalanced cell group but without proper voltage testing you can't guess what is wrong.
February 4, 20206 yr and it would cut out. a voltage display at the battery showed voltage to be fine, even though the display was showing it as low. the problem turned out to be the main power feed to the controller, it had a bad connection
