Reviving a 36V Li-ionDead Battery
Yes don't buy.
For a 2p battery you will want v.good cells min 20a rated, pucker cell's are at least £4 - £7 each.
What current is the board drawing ?
That link would be a total gamble, and the cells would most likely not be 3500mAh, and even if they are, can they supply the amps you need? In your application you need high quality, high capacity cells that can supply a decent amount of amps. Otherwise your scooter won't go far and the pack won't last very long.
Do you know the rated number of Watts you have for your motor?
According to the manual it has a 200 watt motor. It comes with a small remote that allows you to switch from a lower speed to a higher speed with around 9 miles distance on a 2.5 hour charge.
Yes don't buy.
Now your asking! I’ll try find out.
