January 29, 20215 yr After 4 spokes break, it's clear that something is wrong with your spokes or the wheel-build. It's time to respoke the wheel. I'd use 14g spokes. I normally get mine from this guy, but postage has jumped significantly, so probably time to find a UK supplier: https://www.ebay.co.uk/itm/Buchel-40-Spokes-Niro-with-nipples-custom-made-silver/231103012030 Yours are breaking at the nipple end. I'd say they were loose and you ran your bike like that without checking them until it was too late. Thanks a lot for your answer Yes, as you said I never checked before. I guess somehow the wheel center has been moved. So what I will do is to change all of them as you recommend but I dont know the length and the thickness of the spoke. Or as you said “14g” is enough information to buy? Thanks a lot
January 29, 20215 yr Ryan build wheels /Ryan for spokes, I whole heartedly agree with Wheezyrider. I use Ryan for all my spoke needs. 14g = 2mm spokes a bit more flexible then 13g/2.3mm spokes. To ideally get the correct spoke length one need to measure the rim erd (effective rim dia) and then input the results in a spoke calculator. If erd is not known then one needs to accurately measure the rim internal measurement and then add approx 4mm for the thickness of the rim material. Using a spoke calc one inputs all the relevant info needed to get the spoke lengths. Alternately one can take a gamble and remove a good spoke to measure it. If you have never built a wheel up then you have learning curve ahead of you, after a few tries it gets easier. Edited January 29, 20215 yr by Nealh
January 29, 20215 yr You can measure the spokes you already have. Their length will be correct. measure from the middle of the elbow to the end of the spoke - one with a thread, not a broken one.
January 30, 20215 yr If you are going to the trouble of replacing all the spokes, you might want to think about getting a decent new rim at the same time.
January 30, 20215 yr If you are going to the trouble of replacing all the spokes, you might want to think about getting a decent new rim at the same time. I always use the cheapest rims I can find. I never had a problem with one. I've seen problems on other bikes, like rims worn through by the rim brakes, and I've seen rims with cracks around the spokes on expensive rims and also on bikes with 12g spokes.
February 1, 20215 yr Ryan build wheels /Ryan for spokes, I whole heartedly agree with Wheezyrider. I use Ryan for all my spoke needs. 14g = 2mm spokes a bit more flexible then 13g/2.3mm spokes. To ideally get the correct spoke length one need to measure the rim erd (effective rim dia) and then input the results in a spoke calculator. If erd is not known then one needs to accurately measure the rim internal measurement and then add approx 4mm for the thickness of the rim material. Using a spoke calc one inputs all the relevant info needed to get the spoke lengths. Alternately one can take a gamble and remove a good spoke to measure it. If you have never built a wheel up then you have learning curve ahead of you, after a few tries it gets easier. You helped me a lot. Thanks a lot for your time I have one last question. I learnt the size from the seller which are 217mm and 219mm. I will buy them from ryanspokes but should I order anything else? Like nipples? Or when I order spokes, nipples are icluded? Thanks again
February 1, 20215 yr Double check that nipples are part of the order, if not you will ideally want new ones. The shorter spokes will be for the drive/rhs as the rim will be dished over to that side to centralise the wheel in the drop outs. I don't bother with different size spokes and buy one size. A couple of utube videos on wheel lacing as it is easier to lace form scratch then try one at a time, the trueing up of wheel can be done in the drop outs. One can use a cable tie wrapped and cut so a tail acts as a pointer on the rim edge to allow for final trueing.
February 3, 20215 yr I ordered 217mm This is what I received ♂️ anyway, I will follow your advices [mention=9614]Nealh[/mention] thank you su much for your time
February 3, 20215 yr It looks like you got 117 spokes. Your old one doesn't look like 217. As I said before. you should take one of your good spokes and measure it from the middle of the elbow to the ned of the thread. Assuming that whoever gave you the sizes of 217 and 219 was correct. you should choose the middle or upper value because it's more dificult to build with spokes that are too short. There's a bit of tolerance on the spokes being longer than what you need, but not shorter. I'd have chosen 219mm, or 220mm if the seller only stocked standard sizes.
February 3, 20215 yr Make sure you haven't made an error ordering ? Looking at the black spoke it looks about 197mm but as it isn't actually on the tape we can't be sure certainly no where near the 217/219 you mentioned. Start again remove a good spoke from the LH & RHS measure them properly and order them properly. Whom did you order from ?
February 4, 20215 yr Make sure you haven't made an error ordering ? Looking at the black spoke it looks about 197mm but as it isn't actually on the tape we can't be sure certainly no where near the 217/219 you mentioned. Start again remove a good spoke from the LH & RHS measure them properly and order them properly. Whom did you order from ? I ordered from ryan spokes. I double checked of course before I write here and the ryanspokes I ordered 217mm. the one I have, black one, is 211mm but looks 5-6mm is missing screw side. Anyway today I will take of the wheel and try to find a place to built it right away. I am working as a food delivery courier and loosing money of I cant work. I found https://www.bicyclewheelbuilder.co.uk I hope they are kind enough to fix my wheel today Thanks everyone for your time, help and support You all great
February 16, 20215 yr I'm 6'5". It's chilly up here, but not snowbound all year round. AHA! That explains everything.
February 16, 20215 yr AHA! That explains everything. Do you HAVE to be tall to be 120kg? I need to remeasure myself! ~Always thought I was 6 foot...
February 16, 20215 yr I hate fat shaming, I've always cycled between pudgy and fit... I hated being fat, so recently did my Doctor - therefore I took to extreme measures to avoid the need for statins and started intermittent fasting for five days a week: one big meal a day, and ate whatever the hell I wanted on weekends. Overall, the weekly calorie count reduction was enough to lose me two stones gradually over 6 months so far. I still have a stone and a half to go, before the NHS BMI calculator shows relative clear: https://www.nhs.uk/live-well/healthy-weight/bmi-calculator/ ...I don't recommend this intermittent fasting thing to everyone, particularly diabetics. Ask your doc first, I didn't. When it comes to extending range on pedelecs, losing every little helps...
February 16, 20215 yr I’m intermittent fasting and cycling too, after a health scare, down from 143 to 120 so far (since last March). In my defense I was 117kg when I was super fit - just gym/weights/labouring then, not cycling, so aiming for sub 100kg at my age/sport, maybe another 18months. I think that still puts me at obese, which would be wrong. And yeah, you really notice every kg lost on the bike.
February 16, 20215 yr There are several flavors of intermittent fasting, and i find all but the most extreme are much easier to live with than calorie counted dieting. Right now I just restrict eating to 8 hours a day, and my weight goes slowly down. Only black coffee or water in the other 16 hours, not even no cal soda. There are plenty of books on the subject, some quite learned.
February 16, 20215 yr There are several flavors of intermittent fasting, and i find all but the most extreme are much easier to live with than calorie counted dieting. Right now I just restrict eating to 8 hours a day, and my weight goes slowly down. Only black coffee or water in the other 16 hours, not even no cal soda. There are plenty of books on the subject, some quite learned. No calorie pop is fattening. https://www.inc.com/minda-zetlin/diet-soda-weight-gain-metabolism-insulin-brain-fat-metabolic-syndrome.html
