3615dlc-10y0 36v Controller 250w
Does anyone have the wiring diagram for my 36v Controller for a 250w motor
P/N 3615dlc-10y0
Its from a Pro Rider E Tourer ebike I am restoring and someone has made a right mess of connecting the wires.
I thing they are also installed in the Wayfarer Pro Rider bikes.
Thanks in advance
Wiring diagrams don't usually exist, post some pics and we will try to help out.
P/N 3615dlc-10y0
Thanks in advance
Ok I have connected everything up except the following.
PAS has black red green wire
Brake cut out has black red wires
Coming out of the controller I have
X2 blacks red purple blue Wires
The bike is also fitted with 36v lights so I dont know if the controller caters for those the previous owner had them on all the time as soon as you turned battery on so were not connected to controller.
First image shows wires coming from controller
PAS is simple Red/Red5v, Blk/Blk Gnd & Grn/Blu are Signal.
Brakes again are Blk/Blk and the two odd colours Red/Purp to each other. They should be using a simple Reed sensor as only two wires.
If you want lights you can control, one will have to run a pair of power wires from the controller or battery receiver, add an inline Sw and fuse to the voltage Red line
Thanks that what I thought but am worried because the blue wire has a bigger pin attached than the red and black so couldnt have been in the same connector block originally?
Silly me it looks like the red and black have broken pins.
Also does it matter which black wire I use for the brakes and pas?
Does it matter which black wire I use out of the 2?
Thank Neah
I have ordered a new control panel (see below) which has a light switch.
will the yellow + (brown -) wire that come out of it have power for the lights?
