3-D Printer
Don't confuse 3D scanners with photogrammetry, above link is not a 3D scanner but a mechanical aid to take photos of an object that then needs lots of work to stitch together to get anything useable (photogrammetry).
True 3D scanners scan using light and give far superior results.
  • Replies 210
  • Views 43.7k
This is a battery box with supports I printed for the contents of a Yose power 15 Ah silverfish, that had a failed switch and BMS. I was going to write this up as a thread on the forum, but the bike got stolen one week after I finished the project, I didn't even get a chance to take a photo with the correct length bolts fitted to the end flange. Grrrrr!!! If people are interested, I'll post here how I did it.
Did the thieving scum get their warty hands on your battery too?
To make objects which fit around strange shapes, do 3D contour gauges which output measurements exist?
ada13077-1ac5-411a-9b7b-28d4292add41-png.347868
They got the bike and the battery as it was attached at the time.
They'd not get far with a bike on fire - I'm starting to suspect [mention=3847]saneagle[/mention]'s idea of installing a device which shorts the battery after being stolen, is a great one.
Edited by guerney
They'd not get far with a bike on fire - I'm starting to suspect [mention=3847]saneagle[/mention]'s idea of installing a device which shorts the battery after a specified period of time left locked unattended, is a great one.
especially if the flame plume of hot gasses can be directed straight up the seat post..
[mention=26000]WheezyRider[/mention] your unique battery was just too much of a temptation, next time dont do such a good job ;)
the only difference is that mine is self-calibrating, self-testing and self-feeding.
Seems to do a lot.
Cant make a you tea though but can print off a cup.
3D Printed Ceramic Cup, cellular design to protect the hand from the heat (4928 x 3264)
#1 is a stand for working on bike upside down, clip on ones are actually not a bad idea!
#3 is a bell housing as nobody wants to get their bell end wet...
Thanks [mention=39264]lenny[/mention] and [mention=36783]portals[/mention] .. i thought #1 were arm rests but wasnt sure ;)
a dry bell end is important for sure..
Is #3 to keep it dry or to make it look bigger?
It's a reflector to amplify the sound by sending more of it forward.
Sorry, typo. Is #3 to keep it dry or to make it look bigger ;)
I already gave you the answer in the post above!
https://www.instructables.com/3D-Printer-Conversion-to-Automatic-Watch-Cleaning-/
https://www.kickstarter.com/projects/459381052/multi-stage-and-generator-wind-turbine-system
https://www.youtube.com/watch?v=lJJ8-H7XtXs
https://www.thingiverse.com/thing:2933735
https://www.randseq.org/2019/09/line-adapter-for-ozito-blade-trimmer.html
3D Printed Newtonian Telescope Has Stunning Looks, Hadley Breaks The Bank
https://www.printables.com/model/224383-astronomical-telescope-hadley-an-easy-assembly-hig
https://www.cpsdrone.com/
print a ratcheting wrench
https://www.printables.com/model/294886-3d-printed-ratcheting-wrench-with-30nm-max-torque
3D Printed Sorter Separates Spare Hex Nuts
https://www.printables.com/model/289739-metric-hex-nut-sorter-v2
3D Printed Bluetooth Headphones
https://homebrewheadphones.com/3d-printed-bluetooth-headphones/
https://www.youtube.com/watch?v=U-XjbNR1HXg
3D Printed Microscope Lens Adapter
https://www.reddit.com/r/prusa3d/comments/qtjl0y/i_designed_an_adapter_to_turn_a_20_4x_microscope/
https://petapixel.com/2022/06/22/macro-photography-with-a-20-3d-printed-microscope-lens/
https://www.thingiverse.com/thing:5130912
large_display_DSC04256-Edit.jpglarge_display_DSC04218-Edit.jpglarge_display_DSC03999.jpglarge_display_DSC04503-Edit.jpglarge_display_DSC04149.jpg
https://www.youtube.com/watch?v=UN-pXMmCeMs
https://wejn.org/2022/04/improving-physical-security-at-a-hotel/
https://www.youtube.com/watch?v=O74Q1VTz4j4
https://www.youtube.com/watch?v=bLKxT6O0RQk
https://www.youtube.com/watch?v=rPgr2VkYESw
https://www.youtube.com/watch?v=ra_9zU-mnl8
https://www.youtube.com/watch?v=ch9bCGDV5wU
https://www.youtube.com/watch?v=pqaWg85WgUE
https://www.youtube.com/watch?v=hR_zP60qIxs
Testing new RepRaTS 3D printable e-scooter
https://www.reddit.com/r/ElectricScooters/comments/pa0i6u/testing_new_reprats_3d_printable_escooter/
Edited by lenny
