Yes. Sorry that was a slip of the brain! ... There was only one 36 hole rim in stock on the SJS site so I ordered it:Hi Alan, surely the DAPUSH motor hub is 36 hole? Better double check the hole count before you order, hope you have the correct rim. I wonder what size spokes the hub is designed for 14G or 13G? If you order the spokes get some spares and make sure you get brass nipples as well.
Good luck with the wheel build Alan. I have just built the 8Fun BPM motor in a 26" rim, using custom Sapim Strong spokes 13/14G butted. Unfortunately I had to get them from the USA.
Chris
Sun CR18 16 x 1 3/8 / 349 Side Wall Rim 36 Hole
I dont know what the "349 size" means or whether it or any of the other stuff is significant. I've got a 16" wheel and this is a 16" wheel so I'm hoping its going to work! ...
Can you work out the ERD from these stats or do I have to wait for it to arrive?
