That's not right 18K is a completely bogus reading. The phases have very low resistance (like 0.1 Ohms) - so low that most normal meters can't measure it, and zero ohms would be a normal reading
We start building them THIS week John, in fact it's tomorrow! All very exciting. We are building 1350 for this year in lots of about 270 a go. The first production run and much of the second have sold out already. The first container (Built in Taiwan) has just arrived in NZ and reports so far are very encouraging, in deed they are now pushing me to get the second container on the water.I have put a deposit on a new Wisper Wayfarer bike and am hoping that it will be available soon, but I am so determined to finish what I started with this old Powacycle bike . I have put a lot of hours attempting to get it running and I idealy don't want to abandon it.
All the best, David
I would step back from the motor at the mo as it is not getting you anywhere.
Battery voltage and output is good, yes. So retest the controller mosfets disconnect the motor phase/hall wires and test them again, short the controller v+/- together to discharge the capacitor and do the high and low side ohm's test to make sure controller is sound.
When I said disconnect controller I meant fully no battery or motor connections.Thanks Neil. I've got it. I will test them later this afternoon and record readings. Much appreciated.
