I have been wrestling with the reason for a C3 on my LCD display and not being able to get my Powabike Cambridge ebike working.
I bought a second hand Powabike Cambridge model ebike last year as my first ebike and this was my first introduction to the wonderful world of e bikes.
It went well for about 4 months until it suddendly stopped working. I bought a new controller and LCD display as I jumped to the conclusion that the controller was not working.
24V/36V 250W 6Mosfets 15A Brushless DC Sine Wave Controller
After installing the new controller and LCD all appeared normal on the LCD display, but as soon as the throttle was activated I kept getting a C3 error ( Hall sensor abnormality) showing and I couldn't get the bike to work. I spent a long long time checking everything was correctly installed, good continuity accross the connections etc.
To cut a very long story short* I eventually stripped the hub motor apart and replaced the 3 Hall sensors. ( I did notice that the middle Hall senor was in a different configuration from the outer 2 Hall sensors, in that it was reversed relative to the outer 2 sensors. see my diagram:
After careful installation of the new sensors ;and testing the sensors with a newly arrived from China ebike multi function tester which seemed to show the Hall sensors working correctly, I switched on and as soon as the throttle is activated I again get the C3 error message ( Hall sensor abnormality).
So, I am wondering is the controller is not compatible with the way the Hall sensors and associated wiring is configured in the original Powabike set up, and it's the way the Hall sensors are configured that is causing the conflict I am experiencing?
*https://www.pedelecs.co.uk/forum/threads/advice-appreciated-new-controller-purchase.36050/page-2
