2nd Bike Test - Pedal Assist
Quick update on my self-build e-bike...
I installed the pedal assist sensor (was much easier than I thought) and took the bike out this morning for a second test.. Phew, this thing really moves!
I found the highest pedal assist level (there are 6 levels) to be more powerful than full throttle. In fact, I was able to pedal in highest gear (7th) with complete ease from a standing start as though it was 1st gear!
Pedalling in 7th gear I was able to cover a lot of ground very quickly and soon clocked up 3km.. I adjusted the wheel size setting on my speedometer for more accurate speed as last time it seemed inaccurate. I'm still not sure it's accurate. It was showing 36kmph / 26mph going down a very steep hill with full pedal assist and some pedalling. Seemed a lot faster to me, more like 30-33mph. I climbed the very steep hill near my flat and the bike had no trouble at all getting over it in 6th gear with full pedal assist power and some light pedalling. It went up there much quicker than it did last time using full throttle with no pedalling!
I was only out about 20 mins or so as I need to get back for a delivery. The 5Ah battery was fully charged before I left, but very soon one bar, then two bars went out showing the battery was down to 50% power. This was strange because on the first test ride I did using just the throttle at max, the power indicator remained full the whole time, except on a steep hill. As soon as I reduced pedal assist to first level, the power indicator returned to full. I've seen other users describe this behaviour on indicators, so perhaps the indicator is an estimation of how long the battery will last at any given rate of consumption rather than how much power is actually remaining?
I have to say, I much prefer pedal assist to throttle as it just feels more natural to ride this way and I really like the feeling of being "pushed" along! With the 6 levels of assist too, it's great to be able to just set how much assistance you need for different terrains or journey's. The motor is very quiet and you hardly notice it which is a nice bonus.
I decided to keep the battery and controller on the handlebar in the end. I mentioned that I had planned to try moving it to the rear for better weight distribution. I actually bought a rear seat post mounting bag and tried it, but the weight and height of the bag proved to be a problem as it was touching the rear wheel. The only way I can see a rear mount working would be having the bag supported on a rack. I don't like the idea of that as when I install a rack I want to keep it free for luggage!
Besides, I can see no real benefit now to a rear mounting. The front mounting doesn't seem to adversely effect steering and having everything at the front means shorter cabling. I will try to find a handlebar bag that has a quick release mount though as the one I have now is the velcro strap type which is not very easy to remove and put back.
What I need to do next is go out for a proper long test ride and test the limits of the battery for distance, and also do some accurate speed/performance tests. Maybe tomorrow, weather permitting...
