November 26, 20169 yr Author Right then spoke length 162 or 163 will work. Spoke key suggests they are 12g however 2.05mm dia suggests 14g !!! Is the digi caliper calibrated correctly ? Have you a spoke key with 14 to try ? I wouldn't get any spokes until you are sure of the sizing needed. A LBS would be able to confirm spoke sizing my feeling is they will be 12g. Also what bike is it. Hi I have took some more snapshots for you to look at as I have got spoke key wrong, its 13 not 12, definitely not 14 as that wont even fit and when I checked dia with this dig caliper and really push jaws tight onto spoke its about 2.00 maybe 2.01 etc. also when you said about 162 or 163 will work. it was hard trying to remove a new spoke from rim hole as a bit tight to move so its away from rim so i can lay it flat to remove from hole. I will double check before i buy any. probably best to take 1 spoke to a LBS see if they can tell me. but its definitely 13 spoke key not 12 now. http://i.imgur.com/cxnMuYh.jpg http://i.imgur.com/Y4gfZQ7.jpg http://i.imgur.com/aue0Atp.jpg http://i.imgur.com/web7djC.png http://i.imgur.com/fN1pvdO.png
November 26, 20169 yr That makes a bit more sense now 13g or 2.3 mm, the first pic looks right for length so 164mm looks good and the caliper reading at 2.19mm is near as a damn to 13g size. Here a link where you can order the length and quantity you require for not silly money. http://www.tillercycles.co.uk/page2.html
November 26, 20169 yr Author That makes a bit more sense now 13g or 2.3 mm, the first pic looks right for length so 164mm looks good and the caliper reading at 2.19mm is near as a damn to 13g size. Here a link where you can order the length and quantity you require for not silly money. http://www.tillercycles.co.uk/page2.html Hi once again many thanks, but today i went to a LBS so they could measure a spoke better than I did. the shortest spokes they had was 168mm so no good but like I said they measured my spoke with a Cyclo Spoke Ruler. and said its 163mm long 2.34mm diameter, and of course fits a 13 spoke key. but said nipple is 4mm so is this going to be the same as what you have linked a web page to
November 26, 20169 yr Looks 100%, scroll down the page to the 9th offering @65p per spoke/nipple combo and order your amount and size required. The LBS confirming 2.34mm makes it 13g, your caliper must be a bit out or you tightened the jaws to much. Edited November 26, 20169 yr by Nealh
November 26, 20169 yr Author Looks 100%, scroll down the page to the 9th offering @65p per spoke/nipple combo and order your amount and size required. The LBS confirming 2.34mm makes it 13g, youir caliper must be a bit out or you tightened the jaws to much. so order say 6 of these spokes which I take it is complete with nipples. http://i.imgur.com/ikTRmsq.png also I will buy one of those spoke keys as seem better so do i order that red one http://i.imgur.com/an5rZbu.png
November 26, 20169 yr Yes they are the spokes and the nipples come with them. I use a hardened black spoke key as you have got and find it very good, for 4mm nipples you need the blue one if you want that type but have to ask them to modify it.
November 26, 20169 yr Author Yes they are the spokes and the nipples come with them. I use a hardened black spoke key as you have got and find it very good, for 4mm nipples you need the blue one if you want that type but have to ask them to modify it. Dam I went and ordered the red one. Unless I can order the blue one and cancel red one. But don't think I can now. It's just that I like those type of spoke keys.
November 26, 20169 yr Email them and ask for confirmation to change the key, or try phoning them on the chance they might be there to answer on a Sunday.
November 26, 20169 yr Those spoke keys have a square hole. If you get the wrong size, you can lick one side with a Dremmel's carbide disc to make it fit. The keys with a diamond-shaped hole are much better. They don't round-off the nipple. https://www.topeak.com/global/en/products/shop-tools/570-duospoke-wrench-13g---4.3-mm
November 26, 20169 yr Author Email them and ask for confirmation to change the key, or try phoning them on the chance they might be there to answer on a Sunday. Well I have now also ordered the blue key which says modified to 4.00mm And also have e-mailed them too stating I ordered red by mistake. So hopefully they will refund me the red one I had a go at replacing a spoke key the one I took measurement from. You have to really bend the spoke to fit back to the hole in rim. So I hope when I tighten them it will straighten them
November 27, 20169 yr Spokes don't mind being bent when inserted. Once in place, do your best to straighten by hand. The rest will pull out when you tighten them.
November 27, 20169 yr Author Spokes don't mind being bent when inserted. Once in place, do your best to straighten by hand. The rest will pull out when you tighten them. ok thanks for that d8veh much appreciated Those spoke keys have a square hole. If you get the wrong size, you can lick one side with a Dremmel's carbide disc to make it fit. The keys with a diamond-shaped hole are much better. They don't round-off the nipple. https://www.topeak.com/global/en/products/shop-tools/570-duospoke-wrench-13g---4.3-mm well when i asked in a bike shop they said my spoke nipples are 4mm I have placed some snaps below. the nipples look 4 sided to me square http://i.imgur.com/H2nEJLo.png http://i.imgur.com/mxy1boL.png
November 27, 20169 yr Author Email them and ask for confirmation to change the key, or try phoning them on the chance they might be there to answer on a Sunday. I got a reply from the bike shop who is sending the spokes etc and spoke key he said this below. he didn't receive my 1st mail telling him about error Hi , sorry not had that email, the red key will suit the nipples that come with the spokes 4mm refers to the body size not the key side, best to confirm this before I send you the wrong one. Thanks Graham I dont see what he means by body size I have now had another e-mail from the bike shop supplying the spokes he has said this I can not tell what size key your nipples need as you are using a spoke key with old gauge measurements, spoke nipples are now produced in mainly three sizes (across the flats) 3.23mm. 3.30mm, 3.45mm, 4mm refers to the round body of the nipple, the round part of nipple between the flats and the head, so your bike shop might of meant that or across flats of a 5mm nipple which uses a key of 3.96mm or 4.00mm. The D.T Champion 13g spokes come with a nipple that uses the 3.45mm across the flats nipple so you need to check the measurements of across the faces of your nipples with a vernier, the 5mm body nipples only usually come with the Sapim Leader 13g but if you can tell me which you need I will supply the nipples with the correct spoke key. have now received another mail from bike shop he now says this O.k so we have established you need 4mm dia nipples for your rim so I will send those and the red key (and refund the blue one) there are a lot of odd size nipples from non branded suppliers so I can not tell from pictures, you will need to use your multi spoke key for your 3.64 nipples. Edited November 27, 20169 yr by billyboya
November 29, 20169 yr Author I have recieved the new spokes, but something is badly wrong as the thread is poking through the nipple. but when i measure them with old spokes they same size 163mm thats what i was told at a LBS. I have even tried my old nipples and its still same the spokes alternate on each side so i know its right, I have included some snaps shots http://i.imgur.com/0y2fSTJ.jpg http://i.imgur.com/o8Dl3ui.jpg http://i.imgur.com/lcxnU8N.jpg
November 29, 20169 yr I have replied by pm. For benefit of others who may end up with similar issue then I can only say that the spoke laced through the hub (if a few spokes missing) is being threaded in to the wrong nipple. If the new spokes as you say are the same length then there is no other answer, when new to wheel building or replacing spokes it can be easy to make an error esp with a few missing spoke near to each other.
November 29, 20169 yr Author I have replied by pm. For benefit of others who may end up with similar issue then I can only say that the spoke laced through the hub (if a few spokes missing) is being threaded in to the wrong nipple. If the new spokes as you say are the same length then there is no other answer, when new to wheel building or replacing spokes it can be easy to make an error esp with a few missing spoke near to each other. so sorry about that. but something said to me this cant be right, as the spoke lengths are same as the old ones. stupid me has put the spokes in wrong hole. I feel such a fool now and please accept my foolishness LOL.. all 3 spokes went in fine now, just flush with the rim. so screwed on the 3 nipples. and they flush now. would I need to tighten the 3 spokes which are all on same side of hub right up or just a small amount. I have now replaced the rim tape and tube plus the Tyre, and checked its not out of balance its definitely made a lot of difference to the wobble. and more or less no wobble now. just some fine tuning and it should be ok
