May 28, 20205 yr Has anyone replaced the chain on a Torwue 905? I got a SRAM off Amaxon but it is approx 7cm shorter than the original.
May 28, 20205 yr You need a longer chain. Count the links on the old chain and then buy one that has that link count.
May 28, 20205 yr Author Thanks. I've emailed Wisper to see what chain they recommend but no reply yet.
May 28, 20205 yr Thanks. I've emailed Wisper to see what chain they recommend but no reply yet. No need to pay their prices. If you do what Nealh told you, and you can buy in the next shop that is open or oder on ebay or similar! Andy
May 29, 20205 yr At least you will know you are getting the right part that is fitted as standard if you order from Wisper.
May 29, 20205 yr At least you will know you are getting the right part that is fitted as standard if you order from Wisper. Wisper's prices aren't too bad either.
May 30, 20205 yr Had the chain replaced on my Wisper ( now sold ) and the bike shop just joined up two chains to the correct link / length .
June 15, 20205 yr Author Wisper did not respond to my email which is understandable at the.moment. Fortunately I managed to get a chain and new derailleur off Amazon. I found a lile for like derailleur. The new chain is an SRAM PC EX1. It was about 8 links longer than the original so I just cut to size.
June 15, 20205 yr No self-respecting cyclist should be without one of these: https://www.ebay.co.uk/itm/Cycling-Mountain-Bike-Tool-Multi-Function-Chain-Breaker-Bicycle-Repair-MTB-Kit/373078440863?epid=21015567931&hash=item56dd353b9f:g:MZsAAOSwqK9e3wNl The chain-braker tool allows you to break and re-rivet any chain to any length. It's a three minute job.
June 16, 20205 yr Wisper did not respond to my email which is understandable at the.moment. Fortunately I managed to get a chain and new derailleur off Amazon. I found a lile for like derailleur. The new chain is an SRAM PC EX1. It was about 8 links longer than the original so I just cut to size. Hi, so sorry about the lack of contact Stapely. As you can imagine we are crazy at the moment. I will ask them to get back to you tomorrow. May I have your email address? david@wisperbikes.com All the best, David
