Woosh Faro Review
Sorry Reading can’t comment on 32c as I fitted 28c due to price etc will have to do more miles to assess ride and durability qualities. Should have slimed detonators they were comfy enough just overreacting after double puncture, possibly.
Woosh commented he can do the double battery option by fitting a spur on future builds, cost inclusive obviously, but that would be serious range capability.
Be great to have an extended battery
  • Replies 70
  • Views 28.5k
Yes I had front wheel wrong way round but noticed before tightening everything up. I’m sure bar ends I use are cheap certainly less than a tenner new and definitely help. Moving saddle towards handlebars helps with comfort. Glad you’re enjoying tootling around. Great bikes.
Make sure you loosen the small valve nut far enough as the adapter when fitted sometimes closes the nut making inflation difficult no matter what pump
  • 1 month later...
It is also a good idea to depress the nut to make sure that the valve core comes free. They can stick and if they do you can pump away but no matter how hard you push very little (or no) air actually gets into the tube.
  • 2 months later...
Just in case anyone is interested, I put on some bull-horn handlebars (excuse the poor wrapping - it was my first time) and since this pic i have put on 32 schwalbe marathon greenguard tyres (which are lighter than marathon plus but almost as puncture resistant):
Bike looks great, did the 32c tyres fit okay I’m guessing that’s the limit of size if also fitting mudguards.
Max tyre width is governed by D/O size and the bridge width to fit wider guards.
[/quote
Thanks. 32s fit ok - not much clearance but enough for everything to spin as it should! And yes - its the frame clearances that are the critical factor I think...
  • 10 months later...
Is the smaller battery easy to remove from inside the frame for when you want to charge it?
Battery is designed to charge left in the frame Removal is possible for renewal.
  • 2 months later...
Quick update gears working fine after a little adjusting of the cable tension screw. Few additions to how the bike will run, real reason for mudguards is to prevent little stones flicking up onto the nice mat black paintwork [ATTACH type=full" alt="46F4D810-B58E-4C1B-9FD9-30718FDDF35B.jpeg]35740[/ATTACH][ATTACH type=full" alt="DAF9978E-0983-4705-90C3-8F4EB63E27FA.jpeg]35741[/ATTACH]
Hi, I collected my Woosh Faro from Southend a month back and loving it. Very good value, service and riding experience.
Anyway, please can you advise which custom grips have you fitted on the bike?
Hi the main grips are cheappo foam ones from home bargains i think. Bar ends again donated but dirt cheap on eBay Together they prove to be very comfortable.
Have to say, it's a very neat and tidy looking bike, especially the stock pics with the rack fitted. Aesthetically it gives many of the big name brands a run for the money.
I could find it justified me owning a 2nd for shopping, this being it only I fear the frames too small and the max weight too lightweight for my 6'3"* 14 1/2 stone
*I know you can adapt, but 20" for me isnt a good set up, even with a longer stem and higher rise bars.
Very nice, I like it indeed.
And I'd be certainly happier locking this up in the city center rather than my £5k emtb, it just blends in lovely and doesn't look too ebiky and attractive to the rotten mob.
  • 1 year later...
Atlav4, for a much older person with doggy knees and hips, is this an easy bike to ride would you say? :)
Yes it will provide enough oomph
However, I'd only buy it if you need a light bike eg if you have it to carry up stairs
The Woosh Camino or Grand Camino will give you far more bang for your buck
Bigger bike, more power, more comfortable ride. Bigger tires which are also puncture resistant.
Very relaxed upright riding bike which i think they call city style about the most comfortable for knees and hips Some gorgeous cycle tracks to explore fairly easy paced Good no nonsense bikes
So pleased you mentioned some alternatives for me, thanks mate.
You're welcome. Making the right decision is important.
Woosh bikes are easy to derestrict, although they don't encourage it and it negates your guarantee.
Faro will do 18mph derestricted
Camino I'm not sure but at least 20mph so more fun.
