February 25, 20224 yr Billy Milburn a forum member makes and sells batteries, he is located In Durham. Last time he mentioned due to scarcity of getting genuine branded cells he was using genuine China branded cells but even those are now being snapped up as the next best option.
February 25, 20224 yr You could enquire with this guy, he's a forum member and has been building bikes and batteries for a few years now. A few of his satisfied customers have posted here. Tell him the spec of your bike and the fact you ride on throttle only, he may be able to help you. https://eequalspower.co.uk/
February 25, 20224 yr Another member/customer of Bill's here, post #38. Ignore the guy mentioned at the beginning of the thread,i'm eff. not recommending him. https://www.pedelecs.co.uk/forum/threads/battery-repair-recelling.42575/page-2#post-644353
February 25, 20224 yr One of the last recent posts Billy made on here was that he was also using the BAK China cells as nothing else as available, it does appear that some of these cells are quite good value and are good for the current the are spec'd for. What isn't known is the life cycle but if one got two or three years use then the would be deemed good value.
February 27, 20224 yr Author Thanks guys, he said he doesn't ship to Republic of Ireland unfortunately. Any recommendations for someone who can ship to here? Or even better operates here?
February 27, 20224 yr Thanks guys, he said he doesn't ship to Republic of Ireland unfortunately. Any recommendations for someone who can ship to here? Or even better operates here? A name that comes up is EM3EV, and I know from buying non- battery stuff that Grin (why wouldn't you want to buy from a company with a name like that?!) will ship anywhere, but they are Canada. But they know what they are selling intimately, just that balance of assurance vs cost raising its head again. Ebike.ca. I have bought from Psppower for my 48V build, but that is intended for far lower demands than you need, so I can't say it would do for your bike.
February 28, 20224 yr Author Found a highly rated guy on adverts.ie - he doesn't have 3500mAh cells, just 3000mAh Panasonic NCR18650PF. Said the total cost for a new battery to be built into my case (78 of the above cells) would be €455 without an new BMS, or €490 with a new BMS. Interested to hear any of your thoughts on this, thanks.
February 28, 20224 yr Panny PF are meant to be 2900mah cells they are an ok low capacity cell, typically less then 2700mah is there actual rating. Again to avoid any voltage sag use at 5a or less per cell in parallel. I have a 5p PF battery and at 25a it held the sag very stably at about 3.5v climbing up from Ovingdene to Falmer, the cells were already at 3.85v or so and well into the discharge. I was happy with their performance, though there are better cells in the 2900 - 3500 10a range of 18650's. As long as the series bus can handle 30a continuous the choice is reasonable if they are genuine. The 5a discharge alone shows how saggy they are and have a higher internal resistance then other cells.
March 1, 20224 yr Author Thanks. An anomaly I just noticed is the advertisement of the problem battery says the cells are 2500mAh, but the cells are marked as 35E https://www.aliexpress.com/item/4000093945365.html Thanks [mention=9614]Nealh[/mention], the 3000mAh Panasonic NCR18650PF cells is been the only offer I've received so i guess I will go with it. Do you think I need a new BMS also? He can provide this for an extra €35.
March 1, 20224 yr They aren't 3000mah cells, the seller is either egging up there rating or doesn't know cells very well. There are two date codes. Old type e.g. A6 2205 equating to in this case last week in May on the fifth day of 2016. Or new code e.g. B, A over V 8715 equating to 2018 July 15th. Edited March 1, 20224 yr by Nealh
March 1, 20224 yr Author So a Panasonic NCR18650PF 3000mAh cell does not exist? Should I ask the seller for a photo of the cells he will build the battery with?
March 1, 20224 yr I would say yes to new BMS, then the whole battery is the work of the supplier, easier if any issues later. Do you get to keep the old cells? Chopped at 10S and add a BMS could be a usable 36V pack for light use, so they have a bit of value.
March 1, 20224 yr So a Panasonic NCR18650PF 3000mAh cell does not exist? Should I ask the seller for a photo of the cells he will build the battery with? Correct PF are made and sold as 2900mah rating, one can nearly achieve 2900mah but only at 0.2a discharge to 2.8v which is the std industry test. On the other hand independent testers use a more realistic discharge rate. Mooch on ECF only rates them as 2680mah cells, his independent testing and ratings are highly regarded by many in the lion cell world and tend to be used as a bench mark for deciding on any particular cell to use for any project. Panasonic NCR18650PF 10A 2680mAh 18650 Bench Retest Results...an ok low capacity 10A battery | E-Cigarette Forum (e-cigarette-forum.com) Edited March 1, 20224 yr by Nealh
March 1, 20224 yr If using the the full 30a discharge of 6p cells then one can expect about 2050mah per cell (or 12.3mah for the whole battery) at 5a down to cut off at 3.2v, any lower then one is getting into deep discharge territory. My experience is they do sag quite badly as indicated by live voltage readings but they hold up well under sag and give very good power, the voltage rebounds nicely once current demand is lessened.
March 1, 20224 yr Author Thanks. I asked the seller if he mixed up the specification and this is what he said; my apologies, usually it's stated as 2750 or 2900, depending on source. I was able to reach 3000mAh value, of course it may slightly vary between production batch or other circumstances. But I have good experience with this particular cell and have ut in my mind as "3000" cell. here is datasheet: https://datasheetspdf.com/pdf/955257/Panasonic/NCR18650PF/1
March 1, 20224 yr What range are you expecting to need ? We know from early in the thread a 30a controller was being used, do you tend on maxing out the current all the time ? The PF in 6p will have max 17.4ah but at the 30a max draw, the actual usable battery will be approx. 12.15ah/ 580wh worse case scenario. One will only see a out 2025 mah per cell in the p group at 30a draw & I would say one may see 20 - 25 miles max range given it is fat bike, Your main issue will be battery sag as the battery overall voltage decreases, once one gets to 3.6 - 3.7v one is likely to see the sag drop to LVC and cutting out, if so then one will have to use PAS at a lower level to reduce voltage sag. You can't have all the capacity and the current draw. Edited March 1, 20224 yr by Nealh
March 1, 20224 yr Author If I charged between each return trip the longest daily trip is 15km, so should be fine. I guess I can calculate how many A I am using by dividing the Wattage shown by 48V? I generally don't restrict my speed, so I imagine it would be outputting 30A quite a lot? Can I increase my range if I only started to restrict the output near the end of the battery cycle, in the times I am out for a longer ride than usual?
March 1, 20224 yr You wouldn't know the true range until one tries a run out or lots of local short runs until it cuts out to exactly know. Fat tyres will have quite an effect on range via drag, but as you have said speed is the biggest killer for range as assist will be constantly on. I'm only guessing at 20 -25 miles range it may even be in the mid too high teens if maxed out all the time.
March 2, 20224 yr Author Thanks, I'm waiting for the seller to get these cells through customs and then he can get the battery made up. I just tried to hop on the bike for the first time in a few days today, from fully charged it cut out as soon as I turned on the screen without any throttle! Backlight would still light up for what it's worth. Edit - and the backlight would stay on while the controller screen shuts itself off, unsure if this implies anything. Edited March 2, 20224 yr by bikemerchant
March 4, 20224 yr Author I would say yes to new BMS, then the whole battery is the work of the supplier, easier if any issues later. Do you get to keep the old cells? Chopped at 10S and add a BMS could be a usable 36V pack for light use, so they have a bit of value. Yep he said I can keep them, although he suggested I leave them with him to dispose of as he says they can be dangerous.
March 4, 20224 yr If one uses a 18650 torch then they will come in handy once the battery is decommissioned or how about asking him if he will cut out the bad group #11 and remove one cell from all the other groups, then use five of them to replace #11 for a 13s 5p battery it could then be a spare or back up battery.
March 5, 20224 yr Author He said there is no insulation between series so he will have to strip battery down to bare cells and rebuild it. So will take him about 3-4 hours (€120-150) - probably a better option than having the batteries lying around or disposed of? What sort of range would I be expecting from a 13s5p battery?
