July 31, 20232 yr Just wondered what the general opinion is, of these new handlebar mirrors......I have to say it is jolly useful knowing what's behind you at all times.......
July 31, 20232 yr You only need one mirror, and it should be fitted to the right hand side. It should be slightly convex to get a large enough view. Personally, I prefer bar-end mirrors, but all that matters is a good view of what's behind. I like Zafal mirrors, which give an excellent view and are cheep, plus they fold out of the way when you park in a bike rack.
July 31, 20232 yr I use two mirrors - the left is useful on large dangerous multi-lane roundabouts (when I can't find a way to avoid them). I took [mention=3847]saneagle[/mention]'s excellent advice and installed Zefals: Dooback II on the left and Cyclop on the right. I prefer the Dooback II because it snaps into the correct angle instantly, the Cyclop takes more time to adjust. I can't have a Dooback II on the right side, because of how my folding bike folds. Edited July 31, 20232 yr by guerney
July 31, 20232 yr Thanks for the recommendation! They had the RHS ones here https://www.sjscycles.co.uk/accessories/left-zefal-dooback-2-mirror/
July 31, 20232 yr Just wondered what the general opinion is, of these new handlebar mirrors......I have to say it is jolly useful knowing what's behind you at all times....... I find them surprisingly good. I just use just one on the right. I'd prefer a slightly narrower field of view; cars are misleadingly small in the mirror.
July 31, 20232 yr A definite yes to right hand slightly convex such as Cateye BM 500. I used an Oxford mirror for half of my recent trip, before I snapped it off, which was flat and really poor in comparison. All that the bike shop had. New Cateye now fitted, and back to a good view.
July 31, 20232 yr I don't think you'll ever great a great view but at least seeing if there is something behind you is safer than having to look behind to see. I have a zefal dooback grip one on RHS, works OK but is easily knocked, I find it more useful than not so it's still on bike
July 31, 20232 yr I use a Mirrcycle mirror on the right. I wouldn't go out without it. I'm with you there - if feel quite exposed without a mirror. I had as a gift a Garmin Varia, a rear facing warning radar gizmo that does in fact work really well in certain situations e.g. when riding quiet roads two abreast and gas-bagging and not being aware of rearward approaching traffic. The Varia works with Garmin GPS or a smartphone app - I use an app and just keep the phone in my pocket as the beep telling me there's something behind is sufficient to gain my attention. A bit of a toy really but the integrated rear light is good but I wouldn't have spent the dosh on myself though. The Varia isn't great on busy roads though as it's beeping all the time.
August 1, 20232 yr I use a bar end 60mm dia mirror that folds under the handle bar out of the way when not in use on the RHS. Proper glass not plastic mirror. BriskMore Black Bar End Mirrors, HD Glass Convex Lens Bicycle Rearview Mirror, 757233511390 | eBay Edited August 1, 20232 yr by Nealh
August 1, 20232 yr I didn't use a mirror in my younger days when I could easily turn my head to check behind, but as previous contributors have stated, I would now feel quite exposed without a mirror. I've used several different types and found Mirrcycle mirrors to be excellent, but I ended up breaking a couple. I've used cheap Decathlon 'Elops' mirrors for a few years now. They work pretty well and are quite resistant to damage: https://www.decathlon.co.uk/p/100-bike-rear-view-mirror/_/R-p-512
August 1, 20232 yr I prefer a mirror attached to my spectacles, as it provides an apparently larger view & its easy to move your head to sweep behind you. https://www.amazon.co.uk/Third-Eye-Eyeglass-Bicycle-Mirror/dp/B000BDJP66/ref=sr_1_5?crid=1X1URM0SUU4QB&keywords=third+eye+mirror&qid=1690894130&sprefix=thirdeye+mirror,aps,68&sr=8-5
August 1, 20232 yr I prefer a mirror attached to my spectacles Crikey...not too sure about those...all a bit Mr Bean...?
August 1, 20232 yr I've tried the 'mirror attached to the glasses/spectacles arm' type for when I rode a road bike and went for the minimalist look. But TBH they are a bit of a Marmite thing in terms of what they look like to wear and there is a bit of a knack to using them. I note from a google search that there are a number of different styles but one thing to remember is that most of them are 'handed' in that one designed for the LHS of the spectacles won't work very well (or as well) on the RHS and vice versa. The pic below shows this - that one is for the LHS and is better for countries that drive on the right. Edited August 1, 20232 yr by Bikes4two
August 2, 20232 yr Handle bar mounted mirror was at times shaky for me (no front suspension). Take a Look mirror was helpful, it can be used left or right side, can be fixed on helmet/specs and can be kept in your pocket. But not everyone will be comfortable with that, it takes some time to get used to it and gives a goofy look And i cannot ride without one now! Edited August 2, 20232 yr by afzal
August 2, 20232 yr That's an interesting thought, are handlebar mounted mirrors less shaky on front suspension bikes ?
August 2, 20232 yr That's an interesting thought, are handlebar mounted mirrors less shaky on front suspension bikes ? No discernible difference between my two bikes (briskmore mirrors), one with suspension and the other without.. Both excellent.
August 2, 20232 yr Author Well, I've had a re-think on those mirrors......I've stolen this one off me moped, it's bigger, gives a much better view, and doesn't vibrate like those new ones.....I think they can go on the moped.......just been out "on test"....much better !!
August 2, 20232 yr Been using two of the Hafny style mirrors on my cargo bike for the last couple of years (sold as 'Klevsour' but arrived branded and boxed as Hafny). They don't wobble, stay where you position them and have a wide enough field-of-view to get a decent idea of what's happening behind you. Having the left-hand-side mirror as well is definitely useful in busy traffic and on roundabouts and multi-lane one-way systems; helpful for checking he trailer is still attached too
August 2, 20232 yr Been using two of the Hafny style mirrors on my cargo bike for the last couple of years (sold as 'Klevsour' but arrived branded and boxed as Hafny). They don't wobble, stay where you position them and have a wide enough field-of-view to get a decent idea of what's happening behind you. Having the left-hand-side mirror as well is definitely useful in busy traffic and on roundabouts and multi-lane one-way systems; helpful for checking he trailer is still attached too [ATTACH alt=Hafny mirror.jpg]53169[/ATTACH] I tried those, they showed me clear non-shaky views of my elbows. I have 580mm handlebars - wider would have worked out better.
August 2, 20232 yr Just wondered what the general opinion is, of these new handlebar mirrors......I have to say it is jolly useful knowing what's behind you at all times.......[ATTACH=full]53128[/ATTACH] I tried those mirrors on flexi tentacles too - they showed me very shaky views of my shoulders. Bar-end Zefals aren't shaky, even on my non-suspension bike (which has no suspension options whatsoever). I'd prefer a slightly narrower field of view; cars are misleadingly small in the mirror. Objects are closer than they appear using Zefals.
August 2, 20232 yr Take a Look mirror was helpful, it can be used left or right side, can be fixed on helmet/specs and can be kept in your pocket. In an accident, might those cause injury?
August 3, 20232 yr In an accident, might those cause injury? I had not thought about it earlier. Though chances are less (haven't come across any case yet), I think it is possible. Just thinking loud, assuming it worn on spectacle (my case), 1. Probably risk factor would be same or less than that of the spectacles 2. Spectacles might prevent mirror directly hitting the eye, but then spectacle might hit with more force 3. Mirror would be kept slightly offset from the eye, so high chances of it breaking away, thus not hitting the eye. 4. Mirror is harder than normal spectacles, that could aggravate the issue
August 3, 20232 yr Another vote from me for the Briskmore range. I've been offered review samples of most from the range and find them excellent on our touring and folding bikes.
