June 9, 201015 yr Just curious what would i have to do to make a usb power point from a 36v system? sorry to post technical questions in here but i am not allowed to post in the techie forum for some unknown reason
June 10, 201015 yr You need a converter from 36 volts to 5 volts, preferably capable of supplying the standard 500 mA for a USB outlet. These are an oddity and I can only find one at Powerstream in the USA at $30.75. Scroll down the page to the block of four DC/DC converters from 24 to 120 volts and click on the centre link. Then click on the 48 volt version numbered PST DAA 4805. This handles a 36 to 60 volt input for 5 volts output. On the second page of the buying process, make sure you scroll down a bit and select a lower price post option, the USPS Express option is what I use, about 12/15 days to delivery. http://www.powerstream.com/z/dc12-48s.jpg To wire the USB socket that you use to supply power from the converter, view the mouth of the socket where you plug in, with the four metal contacts above the plastic centre support, then the contacts are numbered 1 to 4 from left to right, so you wire to contacts 1 and 4. Contact 1 = +5v Contact 2 = USB - signal Contact 3 = USB + signal Contact 4 = - (Negative/ground) . Edited June 10, 201015 yr by flecc
June 10, 201015 yr Nokia Kit Already invented for Nokia users.... Nokia Europe - Nokia Bicycle Charger Kit - Overview Elaine
June 10, 201015 yr Author Thanks flecc:) Elaine I saw that already, seems you need to mount a dynamo - which would be wasteful on an ebike
June 10, 201015 yr This is what you need - welly boots that charge your phone - from Orange :D Festival boots launched that charge your phone while you dance | Metro.co.uk
June 10, 201015 yr This is what you need - welly boots that charge your phone - from Orange :D Festival boots launched that charge your phone while you dance | Metro.co.uk Forget the wellies, just their content would suit me fine. .
June 10, 201015 yr Forget the wellies, just their content would suit me fine. . Steady on Flecc you should know the (your age/2)+7 rule. She doesn't look 42 to me. xkcd: Dating Pools
June 10, 201015 yr Steady on Flecc you should know the (your age/2)+7 rule. She doesn't look 42 to me. xkcd: Dating Pools That calculation answer should be 44 Harry, I'm 74 this year. Anyway, I'm rich enough to ignore that rule! .
June 11, 201015 yr BioLogic ReeCharge | Dahon Folding Bike Accessories | Dahon Global would this be of any help?
June 12, 201015 yr Forget the wellies, just their content would suit me fine. . Steady on Tony, do you want a heart attack like me:eek:
