bafang crank drive kits
..... 8-Fun have built such a dominant brand image in the West that new entrants to the market will have a very hard time. If they can enrol Frank's help, they may be able to compete.
you´re right about the dominant possion in europe from Bafang.
Even I´m not a fan of Bafang I must admit that they found a way to be popular in europe.
I was one of the first seller in europe who has sold Bafang but Bafang was also the reason why I didn´t wanted to be a seller for e-bike motors anymore afew years ago......
the SFM-Motor I disassemble at the moment is much better as the bafang-crank-drive. This are my my first impressions, the rest we have to check in the future after some hundred kilometer of driving
so now I must order my 100pic´s from inside the motor and check the details into a pdf-file
Just one pic from the torque-sensor
regards
frank
Reactions: trex
trex
7,703
2,671
they try to beat 8-Fun on quality and sophistication rather than price. The issue is how reliable their torque sensor is. Replacing a thumb throttle is easy, replacing that torque sensor is a specialist job. Britain has a love affair with the throttle whereas it's natural to have torque sensor in Europe, I am not sure that we'll see this kit here.
shemozzle999
2,826
686
I see the biggest problem as being the user not using the kit in standard form as the manufacturer had intended. Users tweak the system then blame the manufacturer for any failures:rolleyes:
Reactions: mechaniker
... Britain has a love affair with the throttle whereas it's natural to have torque sensor in Europe...
that´s true and I have a real problem to understand why the throttle is so popular in britain.
Many years ago when I was searching product´s to open a my first conversion-kit shop I thought it would be good to ride the bike with a throttle but after a few weeks using a throttle on a bicycle I was going to be against the throttle because a throttle don´t give me a normal bicycle-feeling.
I kickt my throttle in rubish and used from there on controller with 3 speed-steps later with five speed-steps and then the torque imitation controller as the best solution beside the torque controlled system
And maybe 90% of my worldwide customer´s confirmned me that they felt the same way and nearly every customer take the throttle away from the steering. My customer at that time come from Asia, South-America North-America Australia nearly the whole world but only in britain the customer keep the throttle.... but anyway,
everybody should drive the way he wants to drive as long he also use his legs and not let the motor do the entire work ;-)
regards
frank
ups....
I was to fast or to stupid for a correct reply, maybe I should change my signature ;-)
there is my text:
btw, I think that the poland-company offer the Set for a very good price
regards
frank
30,375
I also don't understand the British preference for throttles Frank, but think it may in part be connected with the British tendency to see cycling as sport rather than transport.
I've owned both kinds of e-bike at the same time and find rides on good torque sensor bikes much more relaxing. Having to cope with the on/off nature of the common Hall effect throttles when riding on bumpy roads can be tiring on long rides, and they make it more difficult to ride economically, minimising current consumption.
awol
1,216
374
I stopped using my throttle a few months ago, now only using PAS level 2 or 3 (of5). I find it much more relaxed cycling and as you say flecc I now get about 30% more miles from the battery.
I was tempted to remove the throttle recently but find it handy to pull me along small gaps where I struggle to spin the pedals.
30,375
Yes, that can be a throttle advantage in very confined traffic situations. However I find it possible to cope with those odd occasions using the pedals in stepping fashion, a slight thrust of a forward pedal and quick slight back pedal to thrust again on that pedal. Another way to describe this is using a pedal as a treadle, a bit like the rocking treadle on foot operated sewing machines.
Kinninvie
907
415
Teesdale,England
I need my throttle when riding in ruts too deep to pedal in.
Also handy when 2 wheel drifting in deep snow.
Other than that I pedal all the time on my BBS02 BUT I do tend to use the throttle a lot on my Dillenger hub kit.
I had to go through some deep fllods yesterday. The throttle saved me from getting wet feet. There's loads of uses for a throttle if you've got one.
30,375
Yes, no question that an independent acting throttle is very useful in situations such as described by Kinninvie and d8veh.
It's on normal roads that I can easily do without one, and indeed prefer a torque sensor for e-cycling relaxation.
Reactions: Kinninvie
D8ve
2,142
1,294
Bristol
For the hard of thinking(reflexes) I find the torque sensor perfect.
The drive is just like riding a normal bike but with bionic muscles.
Having a second control to learn and use would add to my thinking requirement and prevent me sleeping on the bike?
AndrewJ
32
Mechaniker - Any more thoughts on the SFM/TSDZ2 crank drive? Performing well? I'm considering purchasing one from that Polish website; how does it compare to the Bafang?
Hi Andrew,
I like that motor much more as the bafang but honestly,
there is no longtime use experience because the Motor just a few weeks in the market
regards
frank
Fordulike
3,802
1,537
Have you got a link for the Polish website, which sells the crank drive you mention?
Bartek
Aug 21, 2015
I plan to purchase an electric motor and convert my bike (mainly commuting to work in the city). There are some slight elevations in my area and I would like to cycling about 20-25 km/h. I consider buying a TSDZ2 kit from www.btn-ebike.com. But I don't have possibility to do test. it seems to be risky to buy it from China. Maybe someone can tell me is it worth its price? How the torque system works - can you feel any lags in engine work (like cadence sensor)?
Can you give us a link to the listing of what you want to buy rather than the supplier?
BTN is owned by Kevin Fang, who's a very nice funny guy. I've met him a few times and ordered some stuff from him. He's been selling ebike stuff for many years.
Like nearly all the Chinese suppliers he's honest and reliable, but if any mistakes are made on either side, it's very difficult to sort it out because of the shipping costs, so make sure that you know what you're ordering.
Apart from that, it's much better to go for a product that's more universal because there'll be a much bigger shared knowledge base for sorting out technical problems.
Torque sensors don't have advantages that warrant taking a risk. For commuting, a hub-motor system with a speed sensor would be a much more logical choice. If you genuinely don't want to travel over 25km/h and you don't have serious hills, a crank-drive won't offer any advantages for commuting. You'll only notice the disadvantages.
If you tell us your weight and what bike you want to convert, we can advise you which system to get.
Bartek
Aug 21, 2015
This is my bike: http://www.bikekatalog.pl/2009/rowery/1836/Arkus.Classic.1100/ - I plan to buy Shimano brakes, better tyres (maybe Schwalbe Energizer?) and chain.
Link to engine: http://www.btn-ebike.com/mod_product-view-p_id-190.html
My weight: 71 kg.
I have tested an e-bike with 8Fun (this one: http://www.oleole.pl/rowery-elektryczne/no-name-perfect.bhtml?from=pla&gclid=Cj0KEQjwmNuuBRDTu5rDjr2kxJsBEiQAWlm6UikE6iIzZ-Ub0FL5fac4q1f3GWm95GMPMOweLFUrRtMaAoqd8P8HAQ) and I am not satisfied by this kind of bike. The engine reacts to slow and innacurate. There is no smooth cooperation.
