It is the Villari effect
Or the inverse-magnetostrictive effect on which the torque sensor is based.
But first thanks to recent contributors, and to respond :
Cyclezee: Good point about approaching suppliers for a surplus handlebar unit. I will summon up some energy to write begging letter email to the companies you suggest.
Banbury Frank: That is a good idea to resurrect the motor itself with another controller, But I don't have a non-working bike adapted for chain drive to put it in, and I don't have equipment to fabricate a mounting arrangement for another bike. Anyway my aim is to understand how the Panasonic unit works and perhaps even locate the fault in this dud one.
Flecc: Thanks as ever for your pictures and info on your web pages. Following them I have just taken the torque sensor apart and taken a high resolution photo of the shaft which carries the torque from the pedals to the chain wheel. I can now see more than I can with my eyes or in your smaller photos. See below.
I don't suppose anyone here is a member of the IEEE?
Was trying to find out more about the torque sensor and found
this paper on Magnetostrictive torque sensor and its output characteristics which sounds about right. You need a subscription to read the full article.
There are two possibilities for how this sensor works. In one case Both coils are excited and eddy currents are detected as a phase difference depending on the state of the core material or alternatively one coil is excited and a current induced in the other varies according to the state of the core material.
It may be possible to deduce the mode of operation by knowing more about the chips connected to (or near) the torque sensor connector.
I never joined the IEEE - too much money for too little. Thanks for the links. The Journal of Physics paper, I can probably find and read for free in the the library of a nearby University for which I have a free old person's reader's card.
I agree the torque sensor is based on the the Villari effect (never heard of that name before!). See this close up:
In this close up picture I can see that shaft which carries the pedal torque to the chainwheel has fine circumferential grooves. Over the top of this shaft is fitted a gold coloured very thin metal sleeve with two areas of diagonal cutouts oriented at right angles. The two sensor coils (shown in Flecc's picture) fit over the top of these areas.
Now, I assume that the gold coloured metal is has a good Villari effect - it could well operate by changing its magnetic susceptibility when under strain. This will change the impedance of the sensing coil when excited with the 17kHz square wave which I observed to be present. Assuming the two coils are connected in a bridge circuit then the circuit impedance would become unbalanced if the two areas of gold coloured metal have different magnetic susceptibility
The diagonal cutouts on the gold coloured metal respond to the diagonal stresses due to the torque carried in the underlying metal shaft - I assume that the gold coloured metal is a very tight, shrink fit, to the underlying shaft. One are will have experience a higher susceptibility as the metal along the slots is stretched, the other area will experience a lower susceptibility as the metal is compressed in the perpendicular diagonal direction.
Note this type of torque sensor will not provide information on rotation rate or cadence. This information has to be provided to the controller from the motor rotation and the gearing.
Sorry for the long-winded explanation. It is difficult to edit to improve the writing in this tiny edit box!!!
Also, z0mb13e: I will soon strip the potting from the other circuits and see if i can find markings. I will also photo this area of the circuit in close up.
