April 1, 201511 yr I'm in one of the liberal states where 28mph is allowed without license. I do not know if this is something needed and don't know if this is something people want. I'd be interested to hear your own experience and also your opinion about having others riding at this speed.
April 2, 201511 yr Yes I used to hit this speed downhill. In the EU it's not on but if you want to go for it. You need serious brakes. Big disk at the front. Good safety gear. helmet, leathers, treat like a moped as that's what it is! Tough frame to carry a very large battery. It's going to need +30 watts a mile. Very high gearing if you are going to pedal? The power requirement will be high. If you want to increse efficency to get some range then a recumbent/ velomobile would be an idea.
April 2, 201511 yr 28 mph on a racing bike is standard fare, so 28 mph on an assisted bike isn't much different. 28 mph without pedalling is a moped though.
April 2, 201511 yr A 28mph ebike is a much heavier beast than a racing bike, so stronger brakes and a stronger frame are a must (+ the helmet)
April 2, 201511 yr 28 mph assisted speed would be ideal for fast commuting. If used at this speed where safe to do so then is I see no more risk than any other bike. We must not forget that 28 mph is the upper limit and not a fixed travel speed.
April 2, 201511 yr On my bbs02 equipped 750w bike 26mph is the average cruising speed, and downhill it hits mid forties quite easily, but slows to about 14mph on the steeper uphills,I have magura hydraulic disk brakes and since I fitted the kit 3 weeks ago I am suffering terrible brake fade sometimes and have to be careful with my braking on the downhills as you can literally run out of braking power which isn't good. I'm currently looking for an xl frame sized specialised stumpjumper full suspension as the older ones had a straight down tube rather than the modern curved bit at the bottom that the newer ones have
April 2, 201511 yr 28 mph assisted speed would be ideal for fast commuting. If used at this speed where safe to do so then is I see no more risk than any other bike. We must not forget that 28 mph is the upper limit and not a fixed travel speed. The 28 should be on flat and up slight hills. Down hill even faster. But racing bikes only get 28 on closed roads riding in a peloton Never uphill. The acceleration would be deceptive and you can get into trouble easier than an EU limited bike. At seventeen MPH I broke two bones in my arm and one in the wrist. 28 mph is a LOT more energy. Not double but 2.7 times the energy. That is life threatening injuries!
April 2, 201511 yr If used at this speed where safe to do so then is I see no more risk than any other bike. . That is a perfect logical argument. But *where* is it safe for a cyclist to go silently, semi-visibly, relatively unprotected, at moped speeds, without the natural brakes of bodily fatigue, and physical nervousness about hazard? Safe for him and others?
April 2, 201511 yr It's propably safe gor a light fit rider to ride a light roadbike at 28mph, even with narrow tyres and rim brakes; however, put a 100kg rider, and 10kg of ebike kit on the same bike, and it will be a disaster. There's so many variables to consider, but basically, if your bike has tyres and brakes suitable for those speeds considering the overall weight, it shouldn't be a problem. Suspension might help too, but that also depends on the weight and other factors.
April 2, 201511 yr A 28mph ebike is a much heavier beast than a racing bike, so stronger brakes and a stronger frame are a must (+ the helmet) I'm not looking to turn this thread into an arguement, but surely a 15kg normal bike with a 85kg rider would be the same as a 25kg ebike with a 75kg rider. The bike still has to slow down 100kg's of moving mass and I imagine the manufacturers build their bikes with a total weight limit in mind. Therefore, I would have thought total weight would be a better consideration when planning a build. If you are a 130kg chappy, then you may have to consider a more suitable bike, whether it is powered or not. Edited April 2, 201511 yr by Fordulike
April 2, 201511 yr Always good to ask pertinent questions though https://www.micra.org.uk/threads/how-much-weight-can-the-front-passenger-side-take.63940/
April 2, 201511 yr The first thing I would say is why do you need to travel at 28mph? If your comuting routes are on main busy rds I can understand the need for speed however I would not trust bike brakes to stop me safley especially if I needed to come to a sudden stop. The fasted I am comfortable on the flat is 25mph. Though I normally cruise around 20mph. I've done 40mph downhill and trust me on a 19kg weight 20" wheel bike plus me at 11 stone it is seriously a squeaky bum moment!
April 2, 201511 yr Thank god d8veh said tyres. That is my first worry, along with brakes. Having ridden a racing bike as a young man (in town, no helmet) regularly between 45 and 60 kph it is handling in corners and stopping that are the scary bits. The tyres and brakes back in those days have nothing to do with the ones we have now. The other day I was at 40+ in town according to the driver of a truck trying to pass me. It doesn't scare me a bit. I have just upgraded my brake pads from Chinese cr@p to Swiss made ones - OMG were we wrong to send all our manufacturing to China! I have great tyres - Michelin City. I am sure that when the bike is converted I will be seeing 40 kph on a regular basis even with assist only up to 25 kph. Lots of hills around here. If someone opens a car door or steps out from between two vehicules (happened to me) you will not be able to stop in time. If you are on a light weight racing bike the damage will be less than on a 30 kg e-bike that is for sure... Tony
April 2, 201511 yr If you can maintain 28 mph in town traffic you will end up ovetaking most of the cars an trucks either on the inside or down the middle of the road. Either way it seems dodgy to me. Trundling up the cycle lane faster than the traffic can only lead to left turn accidents.
April 2, 201511 yr ... If you are on a light weight racing bike the damage will be less than on a 30 kg e-bike that is for sure... Tony safetyfast's bike weighs 18kgs and cost him £770. By changing his BBS01 with a 48V BBS02, you can get 28mph without pedalling for about £40 more. The issue is you'll go faster more often because you can, therefore increasing the risk of coming up a cropper.
April 2, 201511 yr The route back from my local shopping area in a London borough includes a mile of continuous slightly downhill. Depending on the wind conditions, my normal speed over that stretch is 24 to 28 mph on my 20" wheel bike. It was also the same on my 26" wheel bikes. All were UK restricted so at those speeds unpowered and just pedalling. With plenty of traffic around that's always perfectly safe, even with a few kilos of groceries in the panniers, but of course there are other places and occasions when 28 mph would be too fast for any vehicle. .
April 2, 201511 yr The issue is you'll go faster more often because you can, therefore increasing the risk of coming up a cropper. Damn, I had to take a second look at that sentence. My years in the army, has warped my brain to turning seemingly purer than pure sentences, into double entendre smut fests It's a squaddie coping strategy thing Edited April 2, 201511 yr by Fordulike
April 2, 201511 yr If you can maintain 28 mph in town traffic you will end up ovetaking most of the cars an trucks either on the inside or down the middle of the road. Either way it seems dodgy to me. Trundling up the cycle lane faster than the traffic can only lead to left turn accidents. Not maintain 28mph/45kph reach it. And what is a cycle lane? Come visit the Basque Country, you will love it, no cycle lanes, lots of hills... We ride on the other side of the road so left turns are pretty safe:rolleyes: Tony
April 2, 201511 yr ... We ride on the other side of the road so left turns are pretty safe:rolleyes: Tony Thinking about this, pedestrians are advised to walk on the right in the UK where there are no pavements, so that they oppose oncoming traffic and can react accordingly. On the same basis, where roads have painted on cycle lanes, it would be safer for cyclists to do the same, since then the left turn accident could never happen. Only a right turning vehicle from the far side would come from behind and that would have plenty of warning due to the turning across the whole road to get to that opposing cycle lane. Of course there would be other complexities, but having nothing approaching from behind would be a huge benefit. The outcome would be a very large reduction in cyclist accidents, especially fatal ones, and that could make it worthwhile. .
April 2, 201511 yr Urf, no! If I'm in a car and I see headlights in front on both my left and my right (left from cars coming towards me, right from bicycles in a cycle lane coming directly towards me) I'm not going to know what's what. And all the painted cycle lanes around here have an unnerving habit of disappearing and reappearing, whereupon me as a cyclist would find myself cycling in the wrong direction on a carriageway. If we're on the same piece of tarmac we should be going the same way as the rest of the traffic. We are, after all, all road users. I'd hate to be heading directly towards cars at speed, on the same road. Michael
April 2, 201511 yr It was just a thought that could be valid in daylight. As I said though, complexities, so there could be no glaring headlight at night, just a softer down light. As things stand not a practical idea, but possibly a principle that could have it's uses for cyclists in certain circumstances. Of course here in London we have cycle couriers who ride anyhow and anywhere, including the wrong side of the road. .
April 2, 201511 yr I'm very new to electric cycling and although I've covered tens of thousands of miles in my youth on human powered mountain bikes, this is my first electric bike and I am thinking that 750watts is too much power for my carerra hellcat, although its full suspension, its quite old (1995) and the brakes aren't up to the job at all and the suspension isn't coping with the speed the bumps come up at and it feels a bit too flexible, needs a much stiffer frame too I think. So on that note, if you had £1300 to spend on a second hand bike to fit a 750w bbs02, what would people choose as the ultimate bike to convert to electric ? I'm thinking a specialised camber 29er ? What does anyone else think ?
April 2, 201511 yr Are you good enough to react to a car door opening 10ft in front of you? Are your brakes good enough to stop when a dog or kiddie runs in front on a slippy road? Do you tailgate the car in front at 28mph and can stop like a car? I suspect it is horses for courses,on a wide straight road its probably ok,in London or any big city,its likely you will have a serious prang inside a year. Sigma Sport is next to us,good business for them repairing light sports bikes,yes sir new front wheel and forks,we had to dig the blood out of the brake lever-no charge there,that will be £1600 sir....oh you dont want it back,lost our bottle have we sir,we'll keep it for you once the hospital give you the all clear,its very good business in London, bikes at 28mph. KudosDave Edited April 3, 201511 yr by Kudoscycles
April 2, 201511 yr It's not just about the total weight of the bike as to whether the e bike is as safe as a light weight racer with a heavier rider, it is also about the ratio of sprung to unsprung weight. The heavier e bike is just not as manoeuvrable.
April 2, 201511 yr Cycling on my local cyclepaths on an unassisted bike I usually travel at between 8 and 15mph. For an assisted bike I think 15mph max speed feels about right as I would in any case often have to slow down for blind corners, pedestrians, kids and dogs etc. There is the occasional short straight stretch where with good visibility and no pedestrains slightly faster speeds might be safe, say 17 to 20mph, but 10 to 15mph is about right for the most part. For on road use I think our American cousins have hit the sweet spot with 20mph/750w. The EU 15mph/250w limit I think is perhaps a little too restrictive. A higher power motor would of course allow for more torque which in my limited experience with ebikes seems to be much more important than top speed. I used to ride a Vespa scooter in London where because of traffic I rarely got above 25 to 30mph and yet I often felt very vulnerable and that was with full leathers and crash helmet. I certainly wouldn't feel safe cycling at those speeds. Edited April 3, 201511 yr by 2Lazy
