Failed on my first big hill
Yes but read my post !! Look at current draw from motor !!! We don't have that capability. Leaf has regen and masssive current capability.
You aren't comparing like with like.
My fridge can start pump from Zero rpm and then run it on 100w or so..but it draws around 7 amps (well over a kW) to get there..
If our bikes did that all time we,d havee tiny range. ( Look at ranges for hubs versus cd, its for exactly this reason)
I appreciate that, but that Panasonic rear hub motor has a perfectly acceptable range, comparable with it's competitors. Yes it can use more current when climbing, but at higher speeds and therefore a shorter time. The rest of the time it's using no more current than any other.
CD ranges when high are usually because the rider puts in more effort due to torque sensing.
  • Replies 357
  • Views 67.9k
Look I,m not knocking your bike, it obviously suits you fine...
But exactly what would your hub drive be offering when starting on a 1 in 3 stony climb ?? Mine goes in lowest gear and not only am getting benefit of help the motor is drawing perhaps half ( or less) current to provide same torque at back wheel.
That's exactly why my cd uses less current..nothing to do with cadence .. Yes hub can provide the torque ( obviously) but it can not for equal current draw..
( PS my real job was designing motor control systems for rolling mills, yes not brushless DC but prrinciples on gearing / start up/ efficiency are pretty much same)
Your Hub motor can not spend its life at its optimum efficiency rpm which a cd unit can)
theoretically only though, applicable on long climbs with a constant gradient.
In practice, very often you have to keep changing gears to adapt your pedalling strength to the gradient and narrowness of the path, your CD motor will have to go off then ramp up each time you change gear, reducing the motor's efficiency from its best value.
On short hills or undulating terrains where the gradient is less than 12%, I reckon geared hubs are better than crank drives, especially if you have a high torque motor like the Panasonic, Ezee or Bafang BPM. They become very effective when you ride at over 6mph.
I don't disagree with any of this, but I don't ride 1 in 3 stony climbs.
The essential fact is that changing down with a CD unit to use less current means slower speeds. On my powerful hub motor bikes I use more power and climb much faster in consequence. As Trex remarks, powerful hub motors come into their own as speed rises.
I've owned both CD and front and rear hub motor bikes, including all at the same time for years, so I'm well aware of the advantages and disadvantages of each. Indeed I used to use them in that fashion, horses for courses, but have ended up with hub motor only in my hilly North Downs area.
That's because I increasingly found one long slow climb I have too exhausting with a CD due to the time it took. I preferred to demolish it with more power over a shorter time.
Edited by flecc
Bit fed up with been told I,m talking crap for saying what are basic engineering truths..
It's because you're wrong and you don't listen. You need to take off your blinkers and open your mind.
Sod that! :D
This was bad enough! The cliff drop at the bottom didn't making the prospect of climbing it any easier. Actually the bike didn't make it. I lost traction and this point, and couldn't get going again. The grass was simply too wet.
http://s22.postimg.org/4lrgpa49t/z12_zps48dd7000.jpg
This hub-motored bike that I built, and still have, will go up that hill without pedalling. No problem with traction. It loves slippery grass, mud and snow.
http://i451.photobucket.com/albums/qq236/d8veh/Bikes%20I%20Built/rockyatironbridge_zps8cba1b8a.jpg
Thanks for the info David. Yes, helps very much.
Its a 2015 mk 1 version. There are 3 modes plus 'H' ( I assume meaning 'High'/100% and still in torque mode or does this revert to cadence like 'F' in the 2016 version?).
I was mostly using H, lowest gear and also trying the throttle. I also tried mode 3 and higher gears.
On a side note regarding the LCD controller. I can't find any way to see the MAX/AVG speed and TRIP TIME, which are the bare minimum functions on even the cheapest off the shelf 'bike computer'!
Hi Kevin,
H was changed to F on the Mk2 because strictly speaking H is incorrect, and due to the speedy rider graphic it makes it look like High however it can still be misconstrued as Fast!
My advice on hills is to keep the bike in the 3 mode and use the throttle to regulate the extra power needed. And use the lowest gear available on such steep hills.
I am afraid the LCD does not have many of the basic bike computer capabilities, it doesn't make sense considering the price of the display, I will ask the question.
All the best, David
Never. I might require a little more help up the hills though. I have my doubts about this whole F button, it sounds like an idea dreamed up by someone who doesn't actually ride a bike.
Hi Artstu, to the contrary, it was dreamed up by people who do ride bikes for people who don't.
All the best, David :)
It is very hard for me to comprehend anyone asking for more power on the flat :eek:
There are occasions where it's a good option. I'm thinking of the very fierce headwinds often suffered over wide flat plains such as the Dutch polders and some areas of our Eastern Counties.
They can drag cyclists down to a near standstill. It's a key reason why pedelecs are so popular in famously flat Holland.
Its not a throttle, its an accelerator.
To be currently EU politically correct it is an "Accelerator Handle" although it could change by the next meeting if they stay true to form.
From the point 4 of the MCWG meeting, 15 December 2015
"The ACEM representative pointed out that industry associations ACEM and Conebi had submitted their position paper addressing the issues of assistance factor 4 and powered cycles equipped with an accelerator handle. There is a need to further discuss these subjects in detail at the expert level in a next quadrilateral meeting"
I think I will still call it a throttle like millions of inhabitants of the planet appear to be comfortable with.
What and interesting and amusing thread! I have had to back off spending so much time here as I have had to concentrate on the business. Pedelecs is too addictive!
It is fun to see so many people discussing why the bike they have chosen is the best, but consider.
We (just us at Amps) sell bikes with six different motors...
1. High torque, "torque sensor" rear hub
2. Standard torque, "cadence sensor" rear hub
3. High torque, "torque sensor" front hub
4. Bosch Active (standard torque) mid motor
5. Bosch Performance (high torque) mid motor
6. Bosch performance CX (very high torque) mid motor
Then we then have twelve transmissions...
1. 7 speed Shimano Tourney
2. 8 speed Shimano Acerer
3. 9 Speed Shimano Sora
4. 10 speed Shimano Deore
5. 11 speed Shimano Deore XT
6. Shimano Nexus 7 hub
7. Shimano Nexus 8 hub
8. Rohloff 14 speed hub
9. Nuvinci 360 CVT
10. Nuvinci 380CVT
11. Nuvinci Automatic
12. Sram 27 speed dual drive
Five battery sizes
1. 300Wh
2. 375Wh
3. 400Wh
4. 500Wh
5. 575Wh
Five wheel/tyre sizes
1. 20"
2. 26"
3. 27.5"
4. 28"
5. 29"
Tyre widths from road to fat tyres. Step through frames, mixte frames, mountain bike frames, road bike frames, hybrid frames. No suspension, budget front fork suspension to Fox air front forks, full suspension to Fox Air Float CDT Remote. Frame sizes from 43CM to 63CM.
As I say, that's just from the Amps stable!
Just like vanilla bikes, electric bikes come in many thousands of permutations in hundreds of price points. They all have their own very special characteristics. To say one is better than another is tricky, they are all so different and are built to do different jobs and to suit different people.
Even though I have so many bikes to choose from I ride a Wisper 905Torque to and from work, is it the best bike we sell? For me probably, that's why I choose to ride it. Is it the best bike for everyone, absolutely not.
Just a thought...
I do love this business!
All the best
David :)
Edited by Wisper Bikes
9. Nuvinci 360 CVT
10. Nuvinci 380CVT
Five battery sizes
1. 300Wh
2. 375Wh
3. 400Wh
4. 500Wh
5. 575Wh
1. 20"
2. 26"
3. 27.5"
4. 28"
5. 29"
Tyre withs from road to fat tyres. Step through frames, mixte frames, mountain bike frames, road bike frames, hybrid frames. No suspension, budget front fork suspension to Fox air front forks, full suspension to Fox Air Float CDT Remote. Frame sizes from 43CM to 63CM.
Just a thought...
All the best
David :)
Everything people want with the exception of an independent throttle for the disadvantaged and elderly.
Oh I forgot about throttles....
As long as the pedals are bing turned forwards, the throttle is simply an assistance regulator. If a rider is exerting even 1 gram of pressure on the drive system and the pedals are turning, that is known as assistance not a full throttle. So as long as a rider can turn the pedals forward they can still have a full throttle.
If they wish to be regarded as experts in the next meeting, they should get their terminology right. Since an e-bike throttle can only reduce the power, not increase it beyond the permitted level without a throtttle, it's a decelerator, not an accelerator.
Electric motors have fantastic torque and speed ranges,way better than ICE but put a multi gear ratio capability onto one and its torque application speed range has got to be increased.
Yes there are ways around it electrically if you don't want a gear box ( with diff ratios) but it nearly always means building motor way more powerful than needed and chucking loads of current at it initially. (especially so if started under load as bikes are)
What you are essentially discussing is efficiency. I hate to tell you this, but a correctly designed DD motor is inherently more efficient than a variable geared system.
The following link is a long thread on ES that tears apart the old myth of the need for gearing with an electric drive:
https://endless-sphere.com/forums/viewtopic.php?f=30&t=47930&sid=414ab6b2143d1222b0fcbcb27e9997e2
So does the throttle override the torque sensing or does it apply only in the Fudge mode?
So, it's really a device for throttling the power delivery. There's probably a word for that.....
Sent from my HTC One_M8 using Tapatalk
I think I will stick to my old technology electric bicycle then.
You sit on it and when you need assistance you twist the decelerator, it's a Wisper 705e;)
I went out on my maiden trip at the weekend on my shiny (now muddy!) new Wisper 905 Torque and I failed miserably to get up my first major hill. I'd only done about 100 yards and ran out of steam so had to give up the ghost and walk up using walk mode :(
Kevin, try to forget all the waffle and theory in this thread, i was in exactly the same position as yourself upon entering ebiking. Got myself a rear hub 250W bike with 48v 11Ah battery, totally, totally useless when it came to a major hill, they just aren`t man enough unless you have a decent level of fitness to push the darn thing to the top.
Now on top of all that you will have a few other problems - ever try changing a tube/flat on a hub motor?!! Spokes tend to loosen/break with a heavy hub on potholes etc. Affects the balance of the bike compared to the low centre of gravity of a mid-drive.
Found out the hard and expensive way, now have a mid-drive kit that`ll climb a wall.
Well said.!! Could not agree more. There is more BS pedalled on here than bikes.!!
Wife and I just back from Derbyshire. She hasn't cycled for 25 years. We did 19 miles and within that were a good deal of relatively hard climbing ( Howden res) She completed ride easy...on a borrowed Bosch mid drive.
Proof of pudding etc ...
Kevin..borrow a mid drive and report back.
Edited by (NoLongerRegistered#15675)
Now I remember why I don't come here that often, obviously there are some of us that know absolutely nothing about ebikes, apparently me included!
Off home now, the guys have finished prepping another 27 Wispers and 4 Riese and Muller Bosch bikes to go out tomorrow. I think I'll try a CX tonight, it's the only Bosch that compares to my usual steed.
Come back Eddieo all is forgiven!!!! :rolleyes::):):)
Happy days!
