The new best headlight
Could a lead be rigged up to run 2 of those battery cases in parallel (8 cells) and with a thicker output wire to provide enough current without another blowup?
  • Replies 750
  • Views 117.3k
the batt pack i have is fine as used it for my other light loads of times with no problems bar the leds on the back going down not long after i turn it on.
the leds look fine so something must have gone in the driver at the back but cant check as glued the led pcb in place.
not as if i even bloody used it never got hot as was not using enough power anyway lol.
sent email to seller see what he says as not left feed back yet tho has 100 bad in last month.
101 now
That's funny
I buy a few things from China and I find that they arrive quickley considering the distance, the sellers are polite if a bit left field language wise, and are happy to try to resolve issues. Lets not forget how much we pay for some of these items.. I think the light in question cost about £15 including shipping half way across the world and the only reason SW bought this light from there is because if this existed in the UK it would cost rather more...... The battery box is another issue tho as I had a few problems with mine so lets see what SW gets back from that seller, who purports to be UK based incidentally..
its all ways a risk as if it does go wrong not much chance of sending it back even if it did cost 100 quid as it just cost way to much to send it back, yet they can send a 99p item for free from there, we getting fkn done over big time lol.
always had a part refund or other item sent out so not a problem as the light i have is better than this one anyway:rolleyes:
if the light did pull that many amps and worked that be one bright light but the cables from the batt was getting so hot so fast it would have started to melt over a few mins.
same will go for the leds on the pcb as 11 of them will get hot and fast why it was only using 2.3a when it worked;)
if i done it right then it was 7.45v
I already told you that you did it wrong.
any ideas fkn thing just went bang pmsl wires getting hot now :eek:
He's had a bad night
its the driver in the light for the leds thats gone but had no problems with my other light.
all the leds look fine so might add some power direct to them from the front ;)
Open a case in PayPal because it just dosent work or not as described and try to get your money back.
Sent from my SM-G920F using Tapatalk
The LEDs might be genuine or at least good copies, but that driver is no way capable of delivering the 11 amps that they'd need to go to full power.
were smoking at 5.5a
and it was so hot the on off button fell off the pcb.
Edited by soundwave
That says input 12v no wonder it blew up! Only getting 6.2v can't have ďone it much good. It also says supports 10w t6 not 11 of them! ;)
Edited by chris_n
my other light is the same and thats not stopped working.
also in the listing for the light it says
  • Power Source: 1 x 8.4V 15000mAh Battery Pack
The point actually being if the load was as it was supposed to be i.e. 110W at 6.2V the current would be 17.5A which would require at least 2.5 if not 4mm cable. It is all tat that is not fit for purpose! I like the line in the description that says function open circuit, short circuit and over loading as if they are all guaranteed!
if you put 17a in to the leds they will melt if you cant cool them down lol
http://i276.photobucket.com/albums/kk37/necromunger666/DSC_0490.jpg
i asked the seller to send me this
http://www.ebay.co.uk/itm/152215520619?_trksid=p2060353.m1438.l2649&var=451405595579&ssPageName=STRK%3AMEBIDX%3AIT
as all the lights on ebay have tiny shite drivers as yes it has 11 leds but no way to power them or cool them down.
That's why they call it candle power ... it all goes to up in smoke..[emoji39]
