May 16, 20205 yr Author no link it was a friend of a friend how had a carrera vengeance how has the same bike we just swapped it over from his working bike same issue so i tried the display on his bike no issues all working
May 16, 20205 yr Author i would have tried his battery but he lost his keys so could not swap it over
May 16, 20205 yr Author right i don't now if this is the right way to turn on a carrera vengeance as i have never had one but it is working now what i did is turn it on but at the same time hold done the mode button the 4 lights come on and then they stayed on showing full battery pressed the mode button 123 no problem now all working
May 16, 20205 yr Author this is a question for a friend he two has a carrera vengeance as well but he lost his key he has drilled the key barrel out he was wondering if any one knows were he can by the barrel from thanks
March 29, 20233 yr my friend has a 36V LCD8H Meter With 5pins Waterproof Connector would this work with the bafang hub or not thanks According to your shared pic, the right display for your ebike should be LED 790 display, not others. Some of the display is too similar, but be sure that the 790 LED display should be the right one. https://topeparts.com/product/790-r-led-dis-play/
March 29, 20233 yr It's an old thread so might be pointless replying . In the end he tried a kt display which didn't work, this was explained to him as not compatible with his LSW controller but he seemed to not listen to the advice. We never did get a final outcome from him.
