Why Ride Rad?
You can do all that without an Eggrider. It's just an interface to make it easy for people that need it to be easy.
And foolproof as well!
  • Replies 134
  • Views 13.9k
the motor is labelled 250w
That is very good. Your bike might have been legal.
...up to the point when you derestricted it.
and I do not exceed 15.5mph
Legally it matters if motor cuts off at that point or not.
but I am fully insured on my Radrunner,
Check small print. All policies I have checked were very clear that bike must be legal. You might be paying for insurance which probably is invalid.
I also think even if I am involved in an accident (heaven forbid!) I would be legally safe.
In case of an accident (touch wood) you might find yourself in real trouble. This is when s**** hits the fan. This is when police and lawyers will check things. It looks like at this moment you are driving an illegal moped without insurance, plates, MOT etc.
my bosch bike is labeled 250w but under the speed limit there is no power limit under that speed.
otherwise you could not climb any hill on it.
and with the speed limit removed i can hit near 40mph on the flat.
Is it not all about choice? I know what the Eggrider does for the torque
Interestingly increase in torque can be achieved legally. It is unfortunate Eggrider seems to be focused mainly on other things like increase of speed and unlocking throttle which makes it illegal.
failed to omit the advantages this has for future maintenance costs.
I am not sure how high costs of maintenance might be. I never spent a penny on that.
As for the debate concerning whether it is, or is not a pedelec, sure the clue is in the name? Ped = Pedal and elec = battery powered, surely the Radrunner has both attributes?
By pedelec I meant legal EAPC.
Would we be having the same conversation if I had changed my Radrunner's 35amp controller? I'm not so sure - but i understand more people upgrade the 35a controller rather than fit the Eggrider - choice I suppose?
The eggrider can be configured to cut the throttle off at 6 kph.
Here is the user manual for the eggrider used on the Rad which has a Lishui controller.
https://manual.eggrider.com/ebike_settings/radpower/
The off road profile however is not UK compliant, but it looks like the off road mode can be locked out.
Edited by AGS
Changing controller is a legal way to increase torque. More Amps means more Power.
...but we would be having different conversation as changing controller would raise some red flags. 35A is a lot... at least for cheap generic battery. Rad does not provide much information on battery they use which strongly suggest no name cells. 35A might be pushing battery to its limits.
Sorry for being a party pooper. How about a compromise? I will say your bike is cool, when you make it legal ;)
Az. - We have a deal!
Ride Rad
I think most of us don’t understand what the eggrider can do. From what I can see from the manual, it can be set up to be UK compliant.
Nice...
...but then what? 30+kg fat wheel single speed bike? How far would it go?
Nice...
Longest roam so far is 24 miles, with just over 50% battery life used
Nice...
Pas level 5 and ghost peddling.
Never go beyond Pas level 3 - ever
You said in your review that range is 25 miles...
Correct - that was before I ventured out to see what I could acheive
OK.. that would make a massive difference. If your range is 25 miles as you said, then you need to buy AA golden insurance policy called " I am a celebrity, get me out of here".
If your range is in fact 50 miles, then I like your bike much more.
In the posted video someone says;
"Though actually the motor is 500W"
People say stuff on YouTube and on forums that isn't true. The only point is whether the motor has 250w stamped on it or not.
It isn't 50 miles. I'd be surprised if it did much more than 35 miles without pedalling. The owner has no way of knowing when the battery is half full without a wattmeter. The LCD and/or Eggrider are non-linear, so give a false impression.
I'd be surprised if it did much more than 35 miles without pedalling. .
I hope Peran won't find out range the hard way. It must be terrible to pedal this thing without assistance.
Peran - just to clarify, did you buy display only or display and controller?
I wouldn't only use the throttle, not interested, has to be PAS, don't go higher than PAS3 ever, what would be the point of not pedaling?
Hi Az. - When I bought my Radrunner, it came with a 35amp controller, and the standard display (non LCD) i upgraded to the new LCD display shortly afterwards which gave me more info on my mileage etc: it did not increase torque or speed, made it easier to read was probably the best feature of it, later I did my research on the Eggrider v2, and then purchased it from Big Game Bikes.
Ride Rad
That doesn't change my opinion. You'll be lucky to get 35 miles. You can't change the laws of physics by wishful thinking, otherwise we'd all be using Swytch kits.
Edited by saneagle
My feeling is if the bike originally had a 35a controller then the bike certainly isn't rated for 250w .
Would be interesting to know the battery continuous discharge rating .
It looks like it has a G062 1000 watt motor. The motor cable is coming out on the brake disk side.
G060 motors have the cable coming out of the chain side.
