How long should my ebike chain last?
  • Replies 169
  • Views 50.5k
I suspect Eddie buys them when they are on offer and its a case of searching the various websites for them during the year.
You cheated - that's a 9 speed! :D
Eddie's bikes are 10 / 11 speed I believe and those chains are more than double his suggested £7. I appreciate £16 for a chain isn't going to break the bank, but was just checking I hadn't missed anything...
Ah. One of mine is a 9 speed and I bought a new chain and 11-36 cassette for £21 from chainreaction. My other bike is a 10speed and TBH there doesn't seem any benefit to the extra gear! Most of my riding only uses 2 or 3 of them once up to speed.
Another small point..
When accelerating up to speed I almost always change up 2 at a time.. Suggesting that so many gears are not needed.
I often do the same.
For info, SRAM say that's the primary reason for premature drivetrain wear on electric bikes... which is why their new electric bike specific drivetrain will only shift one gear at a time (and the gaps between gears a larger supposedly removing the need to double shift).
At £21 for a chain and cassette though, who on earth cares!!??
Yes I have been told that shifting is responsible for chipped and broken teeth.. but getting neatly 4000 miles on one cassette has to be good. New bike had the small front ring so wondering how long that will last.
For the KMC chains I do exactly this, just wait for Chain Reaction to have them on offer.
The SRAM are just off the shelf in the local bike shop. Crazy money given that split links on their own aren't far off this price. I was going to bulk buy a load of them when I bought my recent spare one for the hardtail, but was informed that they won't be going up in cost. I really should pop back and buy some anyway, just in case. :)
I have always used two chains in rotation to increase the life of the chain and cassette.
Every 100 miles I take the chain off and completely degrease it and dump it in some solvent.
Then put the other chain ( already cleaned) on, the cassette is cleaned with a small brush and some Muc Off after each ride, along with the chain being wiped down and re lubed.
This has worked really well for me on conventional bikes, see no reason why it won't prolong the drive chain components on the ebike.
Another benefit is good gear shifting that comes from a cleaner chain and cassette.
Worth the effort for me.
Related to chain wear:
How many cogs can one shift up or down smoothly?
I am thinking about building a mid-drive specific cassette - would 5 teeth be asking too much?
11-16-21-24-28-31-34 for example with the big jumps being changing up downhill. Gears most used on the flat will be 5th and 4th. Changing down on steeper slopes will be a softer 3 tooth change.
From my experience of going back to the first 5 speed gears in the 70's, I believe that more gears ( 10 or 11) are a good thing.
Having say 10 gear cassette enables you to keep a better cadence for most of the time, and also gives smoother shifting as the rear mech does have to bridge a large jump in gear teeth.
Keeping the cadence at an optimum level ( 70 to 90 rpm) gives quite smooth changes .
Hi all,
Must be me then!
I do ride my bike in a way that could lead to faster wear in my transmission and for me it is the top gear cog that starts to be troublesome rather than any of the others.
I just use my bike to get me to work and back and this often involves a 13 mile predominantly off road route to work on the sandy tracks of Surrey that inevitably gets everything dirty however clean it starts before a 10 mile road trip home in mostly top gear.
I probably do around 100 miles a week when I am working and rack the miles up quite quickly and am probably getting a reasonable mileage out of my cassettes before I change them when I think about it.
Like Eddie I view chains and cassettes as things that are going to wear out and need changing.
With the thunder storms I went in the car today and it made me realize that I had not done so for months and that 10 miles is quite a long way. It also made me appreciate how fantastic my sDuro yamaha is to enable me to do the journey every day (I work a 4 day week) on a bike carrying a quite substantial 54 year old me and two full panniers.
For what it's worth, SRAM's EX1 8spd cassette is... 11t, 13t, 15t, 18t, 24t, 32t, 40t, 48t... so smaller jumps between smaller cogs, rather than vice versa.
  • 3 years later...
I know this topics been done to death and I'm still puzzled. I changed my first chain at 600 miles from new on my Bosch CX mid drive ebike. I bought a new KMC X10 chain and after I'd installed it I took out my new Park Tools chain gauge and it said it was 25% worn. I've now done a 1000 miles more and it still shows 25% worn. I am a regular lubricator .
I would chuck that chain gauge. Lubricate the chain when it makes grinding noises. Replace it when it makes grinding noises after you lubricate it.
I'd forgotten this thread, going back to my post 122, I can't believe I'm still on the same two chains and cassette.
The spares I bought at the same time are still in my tool box and gear changes are still sweet as ever.
Dave.
I'm with vfr and don't bother with a chain gauge, and keep just keep an eye on the chain lubing. Once or twice a year I sometimes use a foot ruler and measure for strectch, but generally only change if it starts skipping or breaks. Out on a run I always carry a spare chain, splitter and a few spare chain links.
Thanks guys, clearly I got sucked in by some YouTube hype. I always take a quick link and chain splitter in my tool bag. When I was getting rear tyre punctures before I changed to Scwalbe Marathon plus, I also packed some disposable gloves with my tools, and still do as repairing a chain is a right mucky job.
There are people on Youtube, and on this forum, who think that their cassette is worn after 500 miles, which would be about 10 miles on each cog.
  • 2 weeks later...
