broken cable help
I will start the ball rolling as I mentioned in the PM.
Test and test a again, it's the only way.
It worked to a degree before the wire became twisted and broken, so the shorting that will have occurred has either blown the Halls again or the controller mosfets.
Voltage test the Halls as before and resistance test the controller phases to see if the fets have blown.
It's annoying and probably testing your patience now but it's the only way to go after an occurrence like the motor cable breaking.
  • Replies 257
  • Views 30.4k
="Nealh
You will have to go through all the tests again to find the fault.
The twisting and shorting of the wires has either blow the Halls in the motor or Blown/shorted the controller mosfets, only by testing will you know.
Disconnect the controller Phase wires and if the motor turns by hand ok then it is likely a controller mosfet or mosfets have failed. Confirm by mosfet resistance testing.
I have just removed phase wires from the junction box what go to controller, and wheel does turn freely, but if you touch 2 phase wires together on the cable then it seems there is a brake sticking but obviously no brakes fitted as of yet, its a test I learnt on youtube to test phase wires
I do apologies for all this but Im nearly getting to the stage of calling a scrap dealer, as I honestly thought after all this time, it was ok. I go for 1st dam test drive after 3 months of fixing it. go just less than 1/4 of a mile only for cable to twist and break.
Im afraid Nealh you will have to show me in very simple terms how now do I test the halls, and the controller mosfets. please make it as simple as possible LOL
when you say if the motor turns by hand you mean wheel dont you
Edited by billyboya
You have show that the motor wheel frees up and turns by disconnecting the controller so rules out the motor phases and cable as the issue.
I have already described the process in you other many threads or in the PM's.
Follow the two pdf links for testing.
BlownMosfets.cdr (ebikes.ca)
HallSensorTesting.cdr (ebikes.ca)
ok I will do this later, but just feel this has been going on a good 3 months, But as long as you dont mind helping I do appreciate it lots. are mosfets easy then to replace
I cant seem to find which wire is the ground one. I have a cut out switch with a green/yellow wire which goes to the thick red on controller. is that the ground one.
or is it that black thick wire coming from the controller
are all mine suppose to say 10 ohms like in test as I’m still struggling to find where ground wire is
OK I have done the hall sensors 1st, will try mosfet test later. But it does now seem it could be 2 hall sensors the yellow and blue ones. how do I know what sensors to buy same also with the mosfets,
red + black = 4.31v
black + yellow= 0.13v
black + blue= 2.46v
black+ green= 4.99v
Well I tried the mosfet tests, with ground and no power. the only wire which must be ground is that thick black one coming from controller.
but numbers on each wire test flashed up fast then back to 1. on all 3 phase wires green, blue & yellow
But on the power test it was this
power+green= 498
power+blue= 506
power+yellow= 496
hope this is right now, but it seems to me just 2 hall sensors need replacing, the yellow and blue ones. I don't know if that's right. But I will remove motor cases and check again
Am I doing something wrong as in this video he dont even connect to the power and all his readings stay on the screen. yet mine just flash back to 1. thats no power
Wont it just be easier to replace all 3 sensors in motor, then at least I will know they all fine. then just see if motor runs, if not then it has to be the mosfets. But I dont know what sensors to buy or even mosfets hopefully its not the mosfets
Edited by billyboya
I seem to now be getting proper readings on the mosfet tests as I have now set meter to 200 ohm mode. I will test again and get back to you. Tomorrow
One can only know where the fault lies by testing, guessing or hoping get's you know where when you don't get the answer you were looking for.
Mosfet's are in the controller, one must test them with no power as it is a resistance test using the 20 or 200 ohms range.
Test Black controller wire to the three phases, one usually see's high 9 ohms or occasionally 10 with no power. It really depends on the spec's of the resistance range of the mosfet's.
Then test Red controller wire to phases with no power, the results will be different to the above ones. You may just see 1 as the result or see an ascending numeral result which is fine, if any give a zero result then they are fried.
Two Halls are fried so one will have to go through repairing them.
Usually ss41F bipolar ones, I paid £2.99 recently for three.
Hall Sensor Bipolar 41F SS41 SH41 SS41F Electric Bike Motor Repair with Guide UK | eBay
Edited by Nealh
One can only know where the fault lies by testing, guessing or hoping get you know where when you don;t get the answer you were looking for.
Hi Nealh firstly I am so grateful for all your help, its most appreciated, I honestly thought after 3 months fixing moped. I was all done. and like I said took it less than 1/4 mile not even that, and bugger me, cable twisted, but that's my fault for not having the proper washers on axle etc. But I have now received more nuts anti rotation washers plus torque washers from Erider.
anyway I have now done the mosfet tests, I always thought when it said with power, it was to have battery connected then test. or am I wrong or is it like you said thick red wire is the power. anyway now I have put multimeter on 200ohms setting I'm getting proper readings now. but when i had meter on diode and continuity mode numbers wont read right anyway here is readings below, it seems thank god my mosfets are ok
the numbers was going up fast at 1st then slowed
no power thick blck wire on controller
green= 08.0v
blue= 09.7v
yellow= 09.7v
no power thick red wire on controller
green=17.4v
blue=19.1v
yellow=18.5v
are all hall sensors same sizes then, I have ordered 3 new ones where you said. cheap enough £1 each. but it seems you have to make sure the legs of the sensors don't touch, so not much solder will be needed on each leg. I did see on you tube that you glue in the sensors, is that true then here are images of my sensors,
The mosfets don't give a voltage reading, the reading is ohms resistance.
The one at 8 ohms is quite low and is weaker then the other two it should be nearer to 9.7 ohms.
The Halls will have an identifier number on them, I can't read them as the pic is of poor resolution when blown up. Use a mag glass to red them.
The Green/Yellow phase wires look fried to me and looks like the Green has overheated and the core visible.
The Halls, one has to solder the correct leg and check they are orientated right as they only fit one one with bevelled edge. Use the white sheath to insulate the legs when soldered.
You was nearly there with the original repair so will have to try again.
For mosfets try and drain them of the voltage for a better reading, disconnect the controller from the battery and then to touch the controller Black v- & Red v+ together to drain the the voltage. This will give a brief spark but won't do any damage.
Double check the Green mosfet that gave 8 ohms reading and use the 20 ohm scale.
If it still reads low it may be worth replacing it. Also do check them again against the Red wire.
So do you think the green mosfet is bad and needs replacing, as I didnt think I would need to remove controller and open it.
I cant read the hall sensors identifier numbers as nothing on them, probably, rubbed off when i cleaned the motor. But I have ordered 3 from where you said, just hope they same as I have.
No what you thought was fried is just black liquid installation tape
What is that white stuff in circles. as it seems like some strong paste
yes I have had this happen before made me jump as thought i had blown something
ok will do that and get back to you
Im a bit lost as you say disconnect the controller from the battery, But I have not had battery connected at all for these tests, as you said no power. Ive just been testing wires not even connected to battery. But I just did touch thick red and thick black wires on controller together, but no spark. and retested them again
green= 08.11v
green=17.76v
A strong heat resistant double sided tape to ensure the Hall pcb stays attached to the insulation barrier beneath it.
green= 08.11v
green=17.76v
I don't know why you keep insisting of writing up as a voltage test is a resistance test and should be denoted as such by writing ohms or inserting .1644149309741.png.bdeed16718753d307314105298cdb937.png
I would replace the Green mosfet as it is a weak link and may thermally cut out.
I don't know why you keep insisting of writing up as a voltage test is a resistance test and should be denoted as such by writing ohms or inserting .[ATTACH type=full" alt="45632]45632[/ATTACH]
No you getting me wrong, I just said when you quoted about disconnect the battery, was just letting you know I never have battery connected anyway.
I maybe able to solder in the 3 hall sensors by just leaving that white stuff there, as it seems very hard to remove and dont want to crack that board.
Ok so what mosfet do I get or will I have to open controller 1st to check. as I believe there are 6 in all 2 of each - and +
Ok I have now opened the controller, and it seems I was wrong its not 6 mosfets, its 9 it seems 3 for each phase colour. I have looked at 1 and it has on it. so what do I order. the green wire is C then
CS48N78
45195 33S
Well it seems I have made a mistake with checking the mosfets, as now I have removed controller from moped and retested the phase wires its seems its all ok
so it seems the cable just fried 2 hall sensors. btw will those ones I ordered same as you said fit into those slots on motor ok and do they need to be Loctite glued in
thick black wire from controller + green = 9.79 ohms
thick black wire from controller + blue 9.81 ohms
thick black wire from controller + yellow 9.79 ohms
thick red wire from controller + green = 19.48 ohms
thick red wire from controller + blue = 19.46 ohms
thick red wire from controller + yellow = 19.48 ohms
Edited by billyboya
Good, the mosfet's are consistent.
Yes it seems I removed the test probes too quick, as numbers was still going up, so I thought best to wait until they slowed down
Why is there 9 mosfets, do that mean 3 for each phase wire then, and how do you tell which are + and - Im just curious nice to learn stuff
Also I have ordered 3 of those hall sensors as you said. will they be same as mine, and are they stuck in slots with glue. also do they go in slots with the writing facing you.
I will have to be very careful how I solder the legs in as they mustn't touch, well only a small amount of solder on each leg it seems
Btw what did you say that white liquid is called what sets very hard. as I will probably put some over the wires before I close motor case
God its so hard to get the 2 end sensors out middle one was ok as I could push that one easy out. is there a special way to get them out probably a sharp pointed needle
there is some here too.
Edited by billyboya
